It is currently Sat Aug 01, 2026 11:58 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page 1, 2  Next
Post Posted: Tue May 31, 2011 8:23 am
hey guys, i was wondering what a few of you think about 31'' tyres on just a standed 1.3lt 94 sierra. and what offset rims would i get to have a bit of rim stick out of the gauds, i would most prob get that rubber gaud stuff to make it legal, cheers
Post Posted: Tue May 31, 2011 8:25 am
ohh and what size tyre to be exact
Post Posted: Tue May 31, 2011 8:28 am
er, 31's?
2" Body lift
remove front bumper outrigger
4.9 transfer gears.
Vehicle: 2018 DMAX
Post Posted: Tue May 31, 2011 8:29 am
What are you trying to achieve? What mods have you done? 31's on a stock 1.3 will be painfully slow and kill your clutch quick. With out lift/trimming/big bumps it will eat you gaurds...
Vehicle: 1995 SWB Sierra TinTop
why do u need to have it hang out of the guards and why do u want 31's? theres alot of good tyres that are better than fat 31's i.e 31 10r15 have shit ground pressure do to the sierra only weighin a tonne. so a smaller track tyre gives u a better ground pressure do to more weight on less area.
95 Sierra SJ70 TinTop
Post Posted: Tue May 31, 2011 8:32 am
there 31's :? i only run them for comps, id never run them on the road haha 29's max with stock gearing
Post Posted: Tue May 31, 2011 8:33 am
im doing a 2'' suspention lift to start with then the idea was going to be 31''s. so besides choping the gauds is changing the gear ratios the only other thing, and how much will that cost? to changw the gearing
Vehicle: 2018 DMAX
Post Posted: Tue May 31, 2011 8:37 am
2" suspension with 31's will require bigger bumps. A 2inch body will help clear the tyres.
http://www.lowrangeoffroad.com/index.ph ... gears.html
Post Posted: Tue May 31, 2011 8:43 am
cheers boostedbrick, so does that include installing, ohh and what do u mean by bigger bumps? do you think 31''s are going a bit too far with out a body lift aswell?
Post Posted: Tue May 31, 2011 8:47 am
thats mine stock as of now
Hey mate..
my set was the following
2 inch spring lift
2 inch body lift
Hammer the unner guard a little
31" federal couragia MTs (quite soft in the side wall.. Bagged well under the sierra weight)
-13 rims.. Tread was just in the guard .. Sidewall stuck out though
6.5:1 transfer gears.
Imho it was a good setup.. Use to do a highway run daily.. Bout 20 minutes on the M1 and it was ok.. Revved a little high but it was very bearable. Every person has there own opinion on it though.
Things to consider when choosing a tyre that will bag down well is how many ply the side wall is.. Thats why the federals are good.
Post Posted: Tue May 31, 2011 9:07 am
hey mate
i was prety much looking at the same thing as you. but after doing my own research (cheers AZ) i have decided to go 29s they still look prety beast and as was mentiond above 30/9.5/r15 will tub out more than a 31 and there for will prety much have about the same. if not more surface area.
-also u have to consider things like
-how heavy it will make the steering
-that you gona burn ur clutch out if ur not carefull
-possibilities of other brakages increased
-the engine is already shit house in the power department. and it is gona feel worse
go have a look at sierradans zuke. he was running 31s on a stockie
he has even chosen to put a 1litre transfer case in (reduced gears)
the ofset u want is atleast a -13 (f100 sunraiser) this will just hang out the wide track flares (u have a wide track) if u want a bit more maybee go up to a -23 max (this has its disadvantages).
also take note of the search function (people on here get pissed of about re posts..... i found out the hard way...)
strongly recomend u go for 30s or smaller
THINKING BEFORE POSTING!!!
Post Posted: Tue May 31, 2011 9:26 am
My dp is a stock 94 sierra with a 30 on the front. I have stock wheels on at the moment, just put my lifted springs in on the weekend and will take to it with a grinder and hammer before the 30s go on. Also got gears on the way from the states
Post Posted: Tue May 31, 2011 10:36 am
can u post that pic
Post Posted: Tue May 31, 2011 10:50 am
Trying to do this from my phone so see if this works
Post Posted: Tue May 31, 2011 11:48 am
this is mine with 31's in not alot of clearance and they tear the inside of the guard to i wouldn't go 31's again with out doing a guard chop or body lift.
Vehicle: Sj70 tintop
Post Posted: Tue May 31, 2011 12:10 pm
i had 31's on a stock lwb nt. didnt touch the gaurd and the speedo was only out 4 to 6 kmh @100kmh. crawling wasnt to good but i drove from brissy to darwin like that without a problem.
experience may differ i spose.
Sj70 tintop
Post Posted: Tue May 31, 2011 2:52 pm
I can't believe your speedo was only 4-6k's out... More like 16/17k's out with 31's.
Post Posted: Tue May 31, 2011 3:12 pm
16 or 17kmh.... you serious, anybody would notice that,
nah mate i drove it with a gps,
plus the seller never would have let me buy it with 31"s had it been 16/17kmh error.
Sj70 tintop
Post Posted: Tue May 31, 2011 3:39 pm
er, 31's?
2" Body lift
4.9 transfer gears.
x 2 ..
Post Posted: Tue May 31, 2011 3:40 pm
er, 31's?
2" Body lift
4.9 transfer gears.
x 2 .. but id go suspension not body .. no need for body im running body lift on my zook and 2 inch suspension and 2 inch shackles and its quite big .. enuf to stick 33s under it quite easy
a simple suspension lift and gearing should be easy job .. and yes remove bumper out riggers
Post Posted: Tue May 31, 2011 9:22 pm
Body lift clear the tyres better than a suspension lift, as you need to limit the uptravel of a suspension lift.
Although I have a 2" suspension lift and 30mm bumpstop spacers on the front (without these the tyres fucked up my guards) and a 1ltr transfer. I am going to get 6.5s soon. But I love my 31's. Great diff clearance. Not everyone needs 31's, but out my way bigger is better.
Post Posted: Wed Jun 01, 2011 2:39 am
It must have been calibrated before you bought it then. No stock sierra speedo will read only 4-6k's out with 31's as they are just over 15% larger in diameter.
Post Posted: Wed Jun 01, 2011 2:44 am
may have been diff ratios? had no idea what diffs were in it.
but crawling was non existent, thats fine as i only know one position for the go pedal, flat to the floor. (offroad of course)
Sj70 tintop
Post Posted: Wed Jun 01, 2011 3:24 am
Is there another ? :mrgreen:
Post Posted: Wed Jun 01, 2011 3:34 am
anything bigger then standard will be shit if the gearing isn't fixed as well.
haha i am putting 33s on mine today.
Post Posted: Wed Jun 01, 2011 3:37 am
Shep, depends on what you are driving on. Suziblu had stock NT gears, and did well on 31s.
Long range in gears is good for sand.
Post Posted: Wed Jun 01, 2011 3:44 am
my old wt hard top on 30s couldn't hold 5th gear on the highway but when i went to 32s and 6.5 gears
it could pull a heavy trailer all day.
Post Posted: Wed Jun 01, 2011 3:49 am
I was able to tow a tandem axle trailer, full of wood with suziblu, in top gear, 2 hills made me go down a cog, but they were the same that dun it even without a trailer.
Mind, she did not want to go above 90k, was like she hit a brick wall.
With lower gears, 90k in the maruti, put ya foot down and go.
Need pics of the beast with 33s mkay.
Post Posted: Wed Jun 01, 2011 4:10 am
whaaaaarttt
what ones?
same rims?
what happened to te old silverstones?
Sj70 tintop
Users browsing this forum: No registered users and 1155 guests
