It is currently Sat Aug 01, 2026 7:47 am
Post Posted: Wed Jun 01, 2011 4:37 am
is fitting swift gti seats into a WT as simple as removing current rails from the seats and drilling new holes to bolt the WT rails to the underside?
Post Posted: Wed Jun 01, 2011 4:47 am
Yes for drivers seat but passenger will require a bit more effort
Post Posted: Wed Jun 01, 2011 4:49 am
cheers
what more do you have to do with the passenger opposed to the drivers seat?
Post Posted: Wed Jun 01, 2011 4:51 am
the seats in my ute had 2inch flat bar bolted on the seat itself
holes were drilled in the flat bar 30mm or 35mm to suit the sierra rails
will get some pics later
Post Posted: Wed Jun 01, 2011 4:56 am
sweet Verm1n thanks - i was thinking a flat bar bracket would be a good way of mounting the WT rails
look forward to the pics
Post Posted: Wed Jun 01, 2011 5:05 am
Utes are different :wink:
The Swift seats are the same width but the mounting points are slightly longer (fore/aft). There is enough room to drill new holes in the drivers rail but the passenger rails are different. I used a wide, flat bar to extend the rails so the front could be mounted.
Post Posted: Wed Jun 01, 2011 5:29 am
U learn something everyday..
I didn't actually know that but will post some pics
just cause I said I would :D
Post Posted: Wed Jun 01, 2011 6:37 am
ah good stuff, right so i need to go get myself some flat bar
cheers guys
Post Posted: Wed Jun 01, 2011 6:49 am
pics of seat rails
Post Posted: Wed Jun 01, 2011 7:12 am
good one mate thanks for the pics
Post Posted: Wed Jun 01, 2011 12:30 pm
You don't need to do that
I just fitted my MK3 seats a couple of weeks back to my 92 WT Hardtop and didn't require a bracket/flatbar for either the drivers or passangers.
On the passanger side just use the original sierra rails.
Use the first bolt (closest to glove box) to "lineup" the seat to the rail. You will need to use the GTi bolts as the sierra bolts are too small so therefore you will need to 'elongate' and make the hole bigger (you will need some washers incase you make the hole too big)
I then lined up the rear hole of the slider onto the seat and roughly drew where the hole will need to go. The GTi seat has fabric on there so just cut that away nicelly and you will find a hole which is 1-2mm off where you require it to be. Elongate and make that hole bigger...a washer and the screws from the GTi seats and you're set :)
Don't make too big of a hole or have a huge head for the nut as you won't be able to slide your seats. The one that bolts to the floor will hit the one that screws into the seat so the seat won't go all the way back. (might not apply if you use the GTi original screws but i found that to be the problem when i fitted the autotechnica seats so thought id just point it out)
If that doesn't make sense and you need to have a look just give me a buzz to organise a time
Users browsing this forum: No registered users and 53 guests
