It is currently Tue Jul 21, 2026 4:13 pm
Post Posted: Thu Jun 02, 2011 11:21 am
Hi all, I was totally fed up with leaves getting through the bars of the vent and getting sucked into the dash fan, so today I knocked up a screen for over the vent. the frame is just something simple out of 25 x 3 mild flat with alum mesh underneath, primed and painted, and held on with counter sunk stainless sheet metal screws. I would have liked a stainless frame, but didn't have any on hand. Just thought I would share this. Have a good one. Regards John T.
Life is what you make it.
Post Posted: Thu Jun 02, 2011 11:31 am
For my new car, I put brass flyscreen mesh under the heater box before I reinstalled it.
Before:
After:
Post Posted: Thu Jun 02, 2011 11:41 am
Hi Steve, I couldn't be bothered pulling the dash apart to get into the guts of the matter. This way the leaves just blow off the top. Cheers, John T.
Post Posted: Thu Jun 02, 2011 11:56 am
thats what i did and yea it works great 8)
josh AKA Bazook
Post Posted: Thu Jun 02, 2011 12:03 pm
Hey Bazook, sounds like you think like me. I am a lazy bugger basically. I look for the simplest, easiest way that will work. The way that Gwagensteve has gone would work too, but you have to get down under the dash to clean it out. I am too old and cranky to do that now.
Post Posted: Thu Jun 02, 2011 10:59 pm
got any pictures mate, sounds like a good idea
My Rig --> Click WWW
Vehicle: LJ80
Post Posted: Thu Jun 02, 2011 11:18 pm
i cut a hole in the heater box under the dash and vacuumed the leaves out
then siliconed a patch over the hole and covered the vent with sheet metal
Post Posted: Thu Jun 02, 2011 11:20 pm
I just pop rivited and siliconed some sheetmetal over the vent.
i also cut a hole but made it the same size as a floor bung, but that was before i did the mesh idea
josh AKA Bazook
Post Posted: Fri Jun 03, 2011 3:53 am
Hi S13RR4, I have pics, but can't figure out how to post them. :oops: Send me your e-mail and I can send them to you.
Cheers John T.
Post Posted: Fri Jun 03, 2011 9:55 am
click 'post reply'
type something in the box
then scroll down ans there should be a 'Browse" button, Click that and browse for the photo you want and click 'OK'.
If you want to add more click 'add attachment'
then click 'submit'
Note your photos need to be 256kb or less so you'll need to reduce them in paint or the like.
I'll pm you my email if that doesn't work
Post Posted: Fri Jun 03, 2011 10:32 am
Pics of the vent before I screwed it into position.
Users browsing this forum: No registered users and 50 guests
