It is currently Thu Oct 29, 2026 7:07 pm
Post Posted: Sat Jun 04, 2011 8:44 am
i need to move the fuel filler hose out of the tyre well. how have people moved theirs?
also what else am i likely to have issues with after fitting 33s?
Post Posted: Sat Jun 04, 2011 8:48 am
All the other people will want your car :helloo:
Post Posted: Sat Jun 04, 2011 11:25 am
i guess you could stick it out the back bumper somehow. Or just leave it in the same spot but run the piping in and out of the cab.
Post Posted: Sat Jun 04, 2011 11:30 am
I installed the vit fuel tank, and run the filler pipe on top the chassis rail.
I only had a bit of rubbing of the guard with 32" pedes, so I chopped the guard so I could raise it 2" with the rest of the body.
WHats the true OD of the 33s your planning?
Post Posted: Sat Jun 04, 2011 11:42 am
timmay just zip tied it back.....
Post Posted: Sat Jun 04, 2011 12:12 pm
i moved the inlet on the tank to the top and ran it straight up through the floor, then made a different metal pipe to connect it to the filler
Post Posted: Sat Jun 04, 2011 12:43 pm
haha might try that. because i only have a 25mm body lift there isnt a great deal of room
to move the filler.
Post Posted: Sat Jun 04, 2011 12:47 pm
what hitting shep?
mines still in the factory position with the 34's
the tyres occasionally rub the tin cover but thats rare.
I do have a fairly large bumpstop ext though
Post Posted: Sat Jun 04, 2011 1:15 pm
rubs the cover thing very easily, i am still working out what gets in the way. i still haven't flexed it properly yet but i can see that the filler is going to cause issues.
i would rather move things or chop them off before putting massive bumpstop spacers in.
Post Posted: Sat Jun 04, 2011 1:38 pm
do my trick - cable tie your digi cam under the chassis pointing at the offending part and go for a drive.... watch the vid then decide whats causing issues and fix =)
Post Posted: Sat Jun 04, 2011 1:44 pm
what the fuck is a digi cam and why would i have one?
i use the "there is rubber all over it therefore the tyre is touching it" method :wink:
Post Posted: Sat Jun 04, 2011 1:47 pm
ROFL... whatever works =)
Post Posted: Sat Jun 04, 2011 7:59 pm
And failure using that method, there is the "that bit of metal that used to be painted and is now all shiney.. something must be touching it more method"
Vehicle: '96 LWB trayback
Post Posted: Sat Jun 04, 2011 10:01 pm
No paint and rusty, old problem. Ignore.
No paint and shiny, either fix the cause or repaint and ignore.
It's a tried and proven method of troubleshooting.
Users browsing this forum: Google [Bot] and 94 guests
