It is currently Tue Nov 03, 2026 10:18 pm
Post Posted: Thu Jun 09, 2011 8:05 am
The level plug on my gear box has been rounded off and I can't get it out.
I decided to fill the box from the top, and took the gear shift out to fill it from there. I can't seem to get any oil in this way. What is the best way to fill from the top?
Pete
Post Posted: Thu Jun 09, 2011 8:11 am
Why won't the oil go in? Best option would be to weld a nut to the filler plug or use a cold chisel to get that bung out, then replace it.
Post Posted: Thu Jun 09, 2011 8:14 am
I thouht filling from the top would be an easier option to start with, but I may have to resort to the weld option. Should I be able to fill through where the gear stick goes in??
Post Posted: Thu Jun 09, 2011 8:20 am
Been a while since I've had a Vit stick out but I'd think it should, may just take a while to dribble thru?
Post Posted: Thu Jun 09, 2011 8:53 am
Does things right the first time. Weld a nut on the plug, remove and replace.
Post Posted: Thu Jun 09, 2011 8:57 am
Vit has a semi remote shifter, would take a long time to fill through the shifter hole...
Post Posted: Thu Jun 09, 2011 9:12 am
Dead right there! Plan B weld nut on, should have done that in the 1st place.
Post Posted: Thu Jun 09, 2011 9:26 am
X2. The oils only passage through to the box is beside the remote shifter rods. You'll be there for weeks!
Vehicle: SJ80, SE416
Post Posted: Fri Jun 10, 2011 2:10 am
I know everyone here is all for welding, but if you don't have one, try this.
Buy a Kincrome 11mm square sump adaptor (yes strange they actually make these - I got mine in a set that didn't have a 10mm so I had to grind mine down anyway), then grind half a mm or so off 2 of the sides until it will almost fit in the rounded hole - hit it with a hammer to jam it firmly in the hole, attach breaker bar and remove the plug. Buy a new plug for next time, and grind the square adaptor to an even 10mm - use that and you'll never end up with rounded plugs again.
Post Posted: Fri Jun 10, 2011 3:56 am
Thanks for the help. I will chase one of those up for next time. I have welded a short bolt on (easier to hold when on your own) and got it out. New oil in, will be able to drive this weekend!!
Users browsing this forum: Google [Bot] and 92 guests
