It is currently Mon Nov 02, 2026 6:06 am
Vehicle: 96 LWB Vit
Post Posted: Wed Jun 08, 2011 12:43 pm
Howdy all,
Got under the vit tonight to adjust the camber pins, thinking they'd shifted the last time I was out wheeling.
This is what I saw.
So the question I have is this.
Who has replaced their Calmini 3" kit struts, and what have they replaced them with?
I've done a quick search and was looking at OME struts, are these the way to go? or are there other more cost-effective items available...
Cheers for the help....
Buddies
I can't leave well enough alone....
Post Posted: Wed Jun 08, 2011 12:46 pm
Dobinsons come in alot cheaper than OME's & there is a possibility that there is a current issue with the quality of the OME struts according to JoeBlow. :wink:
The only other longer strut from memory is Ironman.
Post Posted: Wed Jun 08, 2011 1:27 pm
I personally have Dobinsons on my SWB Vit. They work an absolute treat, nice rebound, and no problems so far (my car is a tourer, but I still take it out hard occasionally).
What do you MEAN "That JCB won't fit"?!
Post Posted: Wed Jun 08, 2011 1:42 pm
mate, just put dobinson struts and spring in my vit. the ride is awesome :) have decent 40mm extension. would recommend them for sure.
Vehicle: 96 LWB Vit
Post Posted: Wed Jun 08, 2011 2:08 pm
So is that 40mm over standard?
Do you know what part number?
Also how much can i expect to pay for these?
Cheers for the info.
Buddies
Post Posted: Wed Jun 08, 2011 2:45 pm
40mm over stock ride height. They also do a 50mm lift. Of course, it all depends on what you have in at the moment, how much your springs have sagged, etc.
I don't know the part number, but the struts themselves should only be around 250-280 a pair, springs around 170-200 a pair, depending on where you buy them from.
Give Tim over at Outdoor Auto a bell, he did the suspension in my car for a decent price
Post Posted: Thu Jun 09, 2011 6:31 am
Here's the part number Part # GS57-620
i cant remember how much i paid for them $140-145 each? but buzbox got his straight from dobinson slightly cheaper from memory.
I have a set sitting in my garage ready for when i fit my steel diff.
Post Posted: Thu Jun 09, 2011 6:37 am
i have dobinson struts in mine and they ride really well and seem to be handling my car just fine. only problem ive had was when i put them in one failed with in 50km of being put in but was replaced no questions asked and was ready to be picked up the next day
Post Posted: Thu Jun 09, 2011 9:12 am
I think i'm going this way as well, looking at buying dobinsons front struts..
but the cheapest price i can get here in perth from a local dealer is $375 for the front pair .. not so cheap!!
Post Posted: Thu Jun 09, 2011 9:22 am
Send dobinson an email, i did to get stockists for south australia and they replied quickly with stockists and the part number.
He said if i have any problems let him know and i could get them through them.
Vehicle: 96 LWB Vit
Post Posted: Thu Jun 09, 2011 10:43 am
Cheers guys, will give dobinson a call tomorrow.
Buddies
Post Posted: Thu Jun 09, 2011 10:52 am
They're based up in Rocky, so they'll probably overnight you a set if its in stock.
Post Posted: Thu Jun 09, 2011 9:38 pm
Are you running the Calmini strut spacer in your set-up?
It's a bit hard to see in the pic.
If you are, you might find the stut is a bit long. If you don't have the spacer in then the Dobinsons strut should be perfect.
Users browsing this forum: Google [Bot] and 91 guests
