It is currently Sat Oct 24, 2026 9:36 pm
Post Posted: Sat Jun 11, 2011 2:27 pm
:helloo: Hi guys.
I need some safety advice on some modified (N/T to W/T spacing) axle housings i bought off ebay.
here are some pics on some of damage and seemingly dodgy fab work. The housings them selves are straight but the perches are a little off. caster angles are good though.
Post Posted: Sat Jun 11, 2011 2:31 pm
8O 8O Fruck that. Maybe try to grind them off and get new perches i know fatzook makes a set i think around the 260 mark for four with free posting.
screwdriver's on ur head impale DropBears :)
Post Posted: Sat Jun 11, 2011 2:35 pm
http://www.twinstickoffroad.com/product ... h-Kit.html Cut them off and reweld (IMO) them with the TSOR perches as dropbear8 said
Post Posted: Sat Jun 11, 2011 2:39 pm
8O 8O Well my price was waaayyyyyy out and i was to lazy for a link. :roll: :roll:
Post Posted: Sat Jun 11, 2011 2:43 pm
Hahahaaaaa Not even Snake Racing are that dear :lol:
Post Posted: Sat Jun 11, 2011 2:45 pm
man u guys are quick!!!
thanks a bunch, will do that. but what do u think about the slightly crushed axle tube?
Post Posted: Sat Jun 11, 2011 2:49 pm
Thats from the U-bolts. I've seen alot of them like that. Should be fine.
The welds look a bit ratty but they should be ok.
Post Posted: Sat Jun 11, 2011 2:55 pm
so u reckon they are fucked, or do u think they are saveable. should i strengthen the tube or leave it? just a bit worried about bending.
Post Posted: Sat Jun 11, 2011 3:17 pm
Are you going to do high speed jumps?
If not, then just leave it. Like I said its quite common. Welding braces to your diffs is more likely to cause them to bend than the dents from the U'bolts.
Post Posted: Sat Jun 11, 2011 8:42 pm
Is it just the pic's, or are those perch's bent.....
Post Posted: Sat Jun 11, 2011 9:00 pm
i know some one that wont be happy you said its dodgy welds :D
spring pads are stock pads cut off and reused, tsor wasn't selling his when these were done. housing are straight and were welded in a brace. the bent bits your are talking about are from u bolts rubbing
Post Posted: Sat Jun 11, 2011 9:01 pm
Your bent :lol:
Post Posted: Sat Jun 11, 2011 9:03 pm
Rusho wrote:
Your bent :lol:
You say that like it's a bad thing.... :crazy:
Post Posted: Sat Jun 11, 2011 10:14 pm
X2 for Fatzook's comments. The workmanship isn't all that great but I can't see anything really terrible happening.
Welding perches properly (taking into account caster, spacing welding etc) isn't all that easy. If the caster and spacing is right with these, leave them alone. They're not going to break - they just look crappy.
Post Posted: Sun Jun 12, 2011 3:44 am
So you know the maker of these axles?
Sorry mate but the welds are not a bad effort. But this is an axle housing I feel if they were inspected they would be failed. Apparently it was done by a boiler maker, I have only completed 2nd yeah back in 2007 and I am quite sure I can do better. No offense, just a concern.
Post Posted: Sun Jun 12, 2011 3:55 am
Thank you all for your input. I feel much better about using these housings. Just hope I have not offended anyone. Will let u know if they break once I put them in the Lwb. The plans are to lift (the least I need to make it work) lock ( front air, back lock rite) gear ( 6.5 transfer) big 33" maxxis bighorns tyres with f100 wheels. Will take me a fair while to do it all while I am at uni for the next 3 years, still buying parts, plans will prob change. Any way, thanks alot :)
Post Posted: Sun Jun 12, 2011 4:12 am
If you are getting an air locker put it in the back for better on road manners, and power steering for the front.
Post Posted: Sun Jun 12, 2011 4:17 am
Ok good idea.
Post Posted: Sun Jun 12, 2011 4:26 am
I was always under the assumption front air was the way to go. Aids in steering ability I thought :?
Post Posted: Sun Jun 12, 2011 4:32 am
Have a look at all the threads on here and all the people that whinge about how crap the autos are on road, banging and clanging all the time and somehow forcing them to change lanes uncontrollably. A decent power steering setup should be sufficent to overcome any heavier steering.
Post Posted: Sun Jun 12, 2011 4:35 am
But won't over come the no turning in mud, try to climb something slippery & you can't turn....
Post Posted: Sun Jun 12, 2011 4:44 am
True, but if you are going to have one auto and one air, and the vehicle will spend most of its life on the road, then on road manners is what most people complain about with auto lockers.
That's what I was kind of getting at :wink:
Should of just said it then.... :roll:
Users browsing this forum: No registered users and 201 guests
