It is currently Tue Oct 27, 2026 4:17 am
Post Posted: Sun Jun 12, 2011 3:47 am
Hi everyone this is my first post. I have a 96 sierra and I've just been prepping to go to the cape. I did an oil change and swapped to 4wd to
lift a wheel on to a spare to give me space to collect the old oil.
Anyway, after that I made a big mistake and whilst the car was still in 1st gear, and the front wheel locks were on, I depressed the clutch and attempted to go from 4wd low range back in to 2wd. Well I never made it,
the 4wd>2wd gearstick has stopped (in neutral I think) and I have no gears at all. I change thru 1>5 without engaging any gear without using the clutch at all, I've totally screwed up!
Does anyone have any idea how I can get my car moving again?
Any help or tips gratefully appreciated.
regards
pete and buddy
Post Posted: Sun Jun 12, 2011 3:49 am
regards
pete and buddy
That'll do it.......
Post Posted: Sun Jun 12, 2011 3:50 am
sure will but how to undo it?
Vehicle: MY2019 Jimny
Post Posted: Sun Jun 12, 2011 3:51 am
Yeah if your transfer case is in neutral, you will have no drive.
You have actually stumbled upon a handy theft deterrent device!
Post Posted: Sun Jun 12, 2011 3:52 am
Put your transfer case into 2wd.
Are you saying your Tcase is stuck? If so, try lifting the stick slightly as you change.
Last edited by lump_a_charcoal on Sun Jun 12, 2011 3:53 am, edited 1 time in total.
Post Posted: Sun Jun 12, 2011 3:53 am
Take the transfer shifter out, you may find the shifter bush is worn out...
ok, well thanx for that reply i've learnt something now, my transfer case is in neutral! I'm such a dunce considering how far I've gone in me little machine!
Post Posted: Sun Jun 12, 2011 3:56 am
Yeh my Tcase is definately stuck, I'm presuming it's stuck in neutral.
I've tried lifting it, no luck, I've also tried rolling the car a bit etc,
no luck there either.
Post Posted: Sun Jun 12, 2011 4:01 am
lift it up with quite a bit of force but move it back to hi4 gently
or rip the stick out and get a new bush and you should be right to go
Post Posted: Sun Jun 12, 2011 4:03 am
ok guys I really appreciate your instant feeback and tips thanx very much.
can I take out the stick from inside the cab and do the bush replacement from there?
Post Posted: Sun Jun 12, 2011 4:07 am
Yep...... 2 boot's & a push down & turn retainer on the base of the stick..
Yes - it can be tricky but it can be done.
Dropping the transfer case out is also pretty easy.
Post Posted: Sun Jun 12, 2011 4:11 am
thanx guys!
Post Posted: Sun Jun 12, 2011 5:56 am
When you going to the Cape?
I'm off next Saturday. Armsup yess!!
SS
Post Posted: Sun Jun 12, 2011 8:49 am
Where are you on the sunshine coast?
Sierra, Ute Chop, Tube Tray, 1.6 EFI, locked F&R,
Vehicle: '94 suzuki maruti
Post Posted: Sun Jun 12, 2011 11:36 am
also easy to drop on your head :oops:
shifter bush is easy to do though. i had a service manual next to me (didnt really need it though) and despite knowing bugger all about cars, took me a couple of minutes to do. can be done without removing the case easily enough.
Users browsing this forum: No registered users and 72 guests
