It is currently Sun Nov 15, 2026 12:07 pm
Post new topic Reply to topic  [ 45 posts ]  Go to page Previous  1, 2
Vehicle: Daisy
Post Posted: Sun Jun 12, 2011 11:06 pm
Now since we are talking about brakes, doing a rear disc conversion requires a compliance plate right?
Post Posted: Mon Jun 13, 2011 12:18 am
What year are the r31 calipers?? Are you running any brake bias control?
Vehicle: LWB Sierra & XL7
Post Posted: Mon Jun 13, 2011 12:19 am
Technically, any modification done to a car needs to be certified by an engineer.
A few years ago I was having a chat with some cops about modifications and engineers certificates and basically they said unless it's a wild engine conversion or loud, they don't usually care.
My previous car was a bit of a sleeper and it was engineered, a couple of times after running my plates and seeing that it was engineered the cops would pull me up to just to check it out. I never got defected, only complimented :)
'92 Vitara & Camper trailer
Post Posted: Mon Jun 13, 2011 12:23 am
'86 - '89
If you wanna fit 31 skyline brakes, you'll find most nissan parts are interchangable, even VL commos
If your having trouble finding Galant rear brakes, let me know or contact Simon at Adelaide Jap Dismantlers. He's always helped me out with odds and ends.
Post Posted: Mon Jun 13, 2011 12:42 am
So VL calipers might be worth a go? Damo what mods did you do to make the Sierra handbrake mechanism to work??
Vehicle: WR250F/Jeep XJ
Post Posted: Mon Jun 13, 2011 1:06 am
Damo wrote:
dank wrote:
yeah ball you are right, shows how long its been since i did it...It's KSI boys!
I thoguht KTI didn't sound right and I never understood why the things are so bloody expenisve as it's just a big bike disc brake caliper. good thing it's its adjustable. with spacer plates that come with the kit.
Really i think that hydraulic is way overkill. Why do that when a cable is so effective and easy to integrate into the stock system?
I've had to adjust my cable once in about the two years it been back on the road...it took all of 5 minutes to loosen the knarps, pull some more cable through and tighten the knarps again.
It's so simple i can't beleive more people don't go down this path. I'll get some pics when I go to the zook again this coming week sometime. Looks similar to the spidertrax e-brake kit but without the bling!
What's the dia of the rotor you used? Losing ground clearance to the rotor would be the biggest drawback.
I'd be guessing the diameter would be around 8-10 inches. I've got a 50mm transfer lift and the bottom of the caliper from memory is no lower than the bottom of the transfer, its tucked up very nicely. I've never smashed it on anything. When i go to the zook again I will get some pics.
Post Posted: Sat Feb 09, 2019 8:06 pm
Grave dig: What are the options about these days. I refuse to run (and cannot with my build) a transfer mounted drum or disc brake set up. I would like something that works with the factory handbrake lever and it needs to be a 'kit' for engineering purposes.
Suggestions?
Vehicle: 94 suzuki stockman
Post Posted: Sun Feb 10, 2019 4:04 pm
not sure as to what your after but maybe something along the lines of this?
Post Posted: Sun Feb 10, 2019 6:15 pm
Uses Mitsubishi Galant calipers
https://www.zukparts.com/Suzuki-Samurai ... -handbrake
Vehicle: 2011 Jimny
Post Posted: Mon Feb 11, 2019 12:08 pm
Running Golf MkIV rear calipers on my jumby, dont think i can fit 15's over them on jimny front discs. I run 16's so not a problem for me.
2011 jimny, 30s, china locker, swift 1.5, pink playboy seat covers
Post Posted: Mon Feb 11, 2019 1:22 pm
Nice, looks like they're pretty cheap new on eBay too.
Vehicle: 2011 Jimny
Post Posted: Mon Feb 11, 2019 1:34 pm
Yeah, i think its that they're common and newish, compared to trying to find calipers from 80's cars.
Vehicle: suzuki ute
Post Posted: Fri Jul 19, 2019 10:16 am
Not sure what parts are used on mine but this is the setup, @gwagensteve may remember what was involved.
Post Posted: Fri Jul 19, 2019 1:19 pm
That was a blend of the now unavailable spidertrax handbrake and a trail tough rear drive disconnect. I
Vehicle: suzuki ute
Post Posted: Sat Jul 20, 2019 8:00 am
Thanks Steve, I had a feeling you would know.
Users browsing this forum: Google [Bot] and 59 guests
