It is currently Wed Nov 04, 2026 4:29 pm
Vehicle: Vitara 90'
Post Posted: Sat Jun 11, 2011 9:22 am
Sorry for not searching, we are in the middle of a job! How do you pull the rear axles out of a 1990 Suzuki vitara?
Post Posted: Sat Jun 11, 2011 9:46 am
edit: just saw it was vit...
try this:
FRONT:
REAR:
The manual says you need to cut the bearing off if you're going to replace it, then hydraulic press the new one on!
Vehicle: Vitara 90'
Post Posted: Sun Jun 12, 2011 12:05 am
Thanks Mate,
It to 3 stooges 11 hours to get the bloody things apart and then back together. We ended up having to build a slide hammer and we also took the diff centre half out because we weren't so sure. Turns out I have an LSD which I'm pretty happy about. It's all back together now and oh so quiet.
Post Posted: Sun Jun 12, 2011 12:48 am
LSD is pretty rare, id yo take any pics of it?
Vehicle: Vitara 90'
Post Posted: Sun Jun 12, 2011 4:43 am
Sorry wasn't thinking about that at 2am lol.
I was very surprised, it looked similar to this link
http://www.4wdspares.com/images_folda/d ... 20reco.jpg
Post Posted: Sun Jun 12, 2011 4:56 am
what led you to believe its an LSD? could you see the clutch packs in there?
did you buy yours modified? I dont believe any vitara was released in Aus with LSD and they were next to unheard of in Japan
Post Posted: Sun Jun 12, 2011 5:12 am
where LSD a factory option or after market?
Vehicle: Vitara 90'
Post Posted: Sun Jun 12, 2011 6:41 am
My mate told me it was, he reckoned that he's worked on them before (LSD's that's not Zooks) and he was pretty sure I had one. I'm not 100% sure though he does fix the army's trucks. Though we all had no idea when it came to the zook.
Do you have a pick of a normal vitara diff? At least I can confirm if it looks the same.
Edit: I'm starting think it might not be, it looks the same as the one in one of the first diff picks in the below link.
http://auszookers.com/index.php?name=Fo ... &start=390
Post Posted: Sun Jun 12, 2011 10:55 pm
heres an lsd
http://www.trademe.co.nz/motors/car-par ... 137745.htm
Vehicle: Vitara 90'
Post Posted: Mon Jun 13, 2011 6:29 am
Oh yeah. I had a chat to my mate last night, he's assured me it's an LSD he also said that the diff has been pulled apart before so looks like someone has stuck one in there as an afterthought.
It does make me think though. Some of the comments I've had from other people while out wheelin they said they were jelous I had an LSD because of the way it was climbing, I told them it was an open wheeler and that just how good Vit's are.
Post Posted: Mon Jun 13, 2011 6:48 am
your mater assures you its an LSD but cant get an axle out?
does it look like in teh pic or did it have holes in it where you could see the gears inside it?
Post Posted: Mon Jun 13, 2011 8:23 am
+ 1 on it not being LSD, jack it up & check the circle spin ratio.
Vehicle: Vitara 90'
Post Posted: Tue Jun 14, 2011 2:16 am
Heh yeah I know it sounds bad but he wasn't sure if it was a remove the centre then the axles like a banjo diff or if it was the other sort. Once we found a pic of the axles he realised which way it was to happen. To me it looked the same as the one in the pic you posted plus he told me he could see the clutch packs.
[quote="Atari"]+ 1 on it not being LSD, jack it up & check the circle spin ratio."[\quote] Explain how and I'll give it a go and everyone can be satisfied :P
Vehicle: Work van
Post Posted: Tue Jun 14, 2011 2:22 am
Both back wheels off the ground spin one wheel clockwise the otherone will anti clockwise for lsd
Swb softie spoa cromo front -50 beadlocks 6.5s :D
Vehicle: Vitara 90'
Post Posted: Tue Jun 14, 2011 2:30 am
Oh ok, it does that. I noticed it when we were pulling it apart I thought open wheel diffs did that also?
Post Posted: Tue Jun 14, 2011 2:36 am
thats for open diffs, LSD will lock both axles together and spin the wheels same direction
better to hold one wheel and try and spin the other, shouldnt be able to
Vehicle: Vitara 90'
Post Posted: Tue Jun 14, 2011 2:41 am
OK I'll give it a try tonight. It'd be nice to have one though it wouldn't change my driving style since i've alway had whatever is in there.
Users browsing this forum: Google [Bot] and 257 guests
