It is currently Thu Nov 05, 2026 11:11 am
Post Posted: Sun Jun 19, 2011 10:01 am
gday guys. how strong is a vitara rear diff? is it going to be stronger than a sierra?
would it be able to run a 35 on rocks?
Post Posted: Sun Jun 19, 2011 10:25 am
From what Im told the ring and pinon is stronger but the axles are similar strength.
Post Posted: Sun Jun 19, 2011 10:29 am
There used to be a sierra back in wollongong running a vit rear diff and 37's. Don't think he had any issues
Member of C.O.R 4x4
Post Posted: Sun Jun 19, 2011 10:35 am
cool, recon a sierra front would hold up tp 35's with cromo axles?
Vehicle: Toyota Hilux
Post Posted: Sun Jun 19, 2011 10:40 am
If your using a vit rear diff in the rear, what are you using up front?
Post Posted: Sun Jun 19, 2011 10:46 am
sierra...hopefully :wink: if the sierra diff cant handle 35's then ill just stick with 33's
Post Posted: Sun Jun 19, 2011 10:47 am
Vitara diffs are wider then sierra
Post Posted: Sun Jun 19, 2011 10:49 am
yeah thats cool, just means ill loose the spacers in the rear.
Post Posted: Sun Jun 19, 2011 10:52 am
wrong off set for the center.
Post Posted: Sun Jun 19, 2011 11:27 am
will that worry it too much you recon? the rear is 400mm longer and the drive shaft is about 920mm.
Users browsing this forum: Google [Bot] and 22 guests
