It is currently Wed Oct 28, 2026 6:47 pm
Post Posted: Sun Jun 19, 2011 9:27 am
My g16b conversion is coming along nicely.
got stuck into the wiring the other day and connected most of the plugs on the engine up.
im using my loom that i got back from killa kustom kables
there were a couple that i couldnt find their mates...
here are some pics of the plugs
1. this black one almost at the end of the loom
2wires (green with red strip/ grey withred strip)
Uploaded with ImageShack.us
2. this yellowish plug
2 wires (brown or orange /grey)
3. these 2 wires. yellow and black. do these go to the crank angle sensor?? (the CAS plug and sensor had been cut from the loom when i bought it)
I also have no idea what these two plugs are for. located on the loom near the plugs for the ECU
4. 4wires (black/ purple with white strip/ purple with yellow strip/ brown with white strip)
5. 3wires (black/ white/ yellow with black strip)
Clumsy me broke 2 sensors when installing the engine mounts. i need to know what these are so i can buy some new ones
6.
7.
Post Posted: Sun Jun 19, 2011 9:43 am
I'd have to go look at mine but
the ones near the ECU are Diagnostics, spare one is normally under the bonnet and the bigger one is for a scan tool
photo 2 might be O2 sensor
Vehicle: 4wd
Post Posted: Sun Jun 19, 2011 9:54 am
Can you list what colour the wires are?
Watch out or you'll get sued.
Post Posted: Sun Jun 19, 2011 10:02 am
yep il go and have a look when i get home later tonight
thanks royce. good to know those 2 are just the diagnostics, i was worried i was missing a part of the loom or something
Post Posted: Sun Jun 19, 2011 11:17 am
My guess'
1. Temp sensor ( there are a few on the manifold)
2. Power steer. Looks like the wire has been pulled out of the plug.
3. NFI
4. NFI
5. looks like a diagnostic
6. Suzuki? :?
7. pollution control. usually mounts to the back of the intake plenum. looks like 1 is missing too, as there is usually a pair of them on that bracket.
Post Posted: Sun Jun 19, 2011 11:26 am
my power steer comes from the guard loom not the engine, though I cant remember if anything more than oil pressure normally loops over the cover like that
Post Posted: Sun Jun 19, 2011 11:57 am
I have edited my first post with the wire colours and the number of wires going to the plugs.
fyi here are the sensors i know i havnt connected yet:
Crank angle sensor and the exhaust sensor in the exhaust manifold
all the sensors on the intake manifold all have matching plugs that are connected.
thanks for the help so far, u guys are awesome! i wouldnt be at this stage of the conversion if it wasnt for you
Vehicle: 4wd
Post Posted: Sun Jun 19, 2011 12:26 pm
Inlet air temp. temp sensor
Check the colours again
Check the yellow again, might have a stripe?
Diagnosis connector
DLC
Post Posted: Sun Jun 19, 2011 1:02 pm
Diagnosis connector
DLC
just double checked, traced the wire back as far as i could checking for joints, some the colours are hard to tell as they are a bit dirty:
2. brown or orange/ white or beige?????
3. white/black????
:D 1. out of the way. stockman u legend
as for 1. inlet air temp sensor. temp sensor
is this normally located on the plastic piping before the air intake?
i dont have any of the baleno airbox or piping
Vehicle: 4wd
Post Posted: Sun Jun 19, 2011 1:18 pm
Diagnosis connector
DLC
Pretty sure it has to be orange/white. My diagrams say there is no brown.
I think this is the Oxygen Sensor, just have a look at the manifold and see if it is.
If so the white one is what you need. The orange was for a heated oxygen sensor?
I went through the hastle of removing the wire and the wrap or insulation but it took a while.
3. white/black????
Crankshaft position sensor
Did you but just the motor or complete car?
Post Posted: Tue Jun 21, 2011 6:37 am
had a look at the exhaust sensor. it does go to that yellow plug. only one wire can go into it, the other 3 holes in the yellow plug are blocked off, and the only one that a wire can go into is the white wire. stockman u are correct :)
as for the crank angle sensor:
i bought the engine and loom from a suzuki wrecker in syd.
the CAS and its plug were left on the engine, separated from the loom.
i didnt realise the plug wasnt on the loom till i got back my custom loom from KKK. the plug was hiding inside the rubber seal on the CAS.
i rang steve from kkk and said he remembered making a loom that didnt have the CAS plug.
im guessing the yellow and black wires do run to it as they are all whats left.
hopefully i have done everything right.
Cheers heaps for all ur help guys. much appreciated :D
Users browsing this forum: Google [Bot] and 287 guests
