It is currently Sat Oct 31, 2026 2:21 am
Post Posted: Mon Jun 20, 2011 12:48 am
ok on the trip to nsw my zook started to have a shit idle, i put it down to blow h/g. but no.
at idle it sounds like it has lumpy cams (it dosnt)
cam timing is perfect.
i just swapped to spare afm and tps
checked for vac leaksthere are none, and cracks in inlet also none..
computer gives no codes.
i am lost...
any ideas?
Post Posted: Mon Jun 20, 2011 12:49 am
oh also as soon as i bring it off idle it runs smooth as. its just at actual idle 1000rpm that it has issues. i have had to up the idle from 800rpm as it used to just stall out there all the time.
Vehicle: LJ50 , LJ80Q-II
Post Posted: Mon Jun 20, 2011 1:05 am
idle air valve?
Post Posted: Mon Jun 20, 2011 1:24 am
they are a manual screw type. not much can go wrong.
Post Posted: Mon Jun 20, 2011 2:40 am
Whats cold idle speed controlled by? Doesn't it have an idle air bypass valve?
Lil Foot!
Post Posted: Mon Jun 20, 2011 2:45 am
yeah it has a cold idle valve that has a thermostat style set up in it. its not the cold start as it does it all the time.
Post Posted: Mon Jun 20, 2011 4:16 am
Sticky valves?
Post Posted: Mon Jun 20, 2011 4:41 am
edit: finger worked faster than my brain function. :oops:
Post Posted: Mon Jun 20, 2011 4:50 am
dont think so dan. its not rattling at all.
Post Posted: Mon Jun 20, 2011 7:20 am
G13B? :D
Post Posted: Mon Jun 20, 2011 7:26 am
How did you check for vacuum leaks? Have you checked the brake booster? Still sounds like a vacuum leak to me
Post Posted: Mon Jun 20, 2011 8:45 am
Yea or air bypassing the throttle body butterfly.
Lil Foot!
Post Posted: Mon Jun 20, 2011 12:23 pm
i think the same. i might disconnect booster tommorow and try.
i checked with the good old spray crc everywhere. nothing.
Users browsing this forum: No registered users and 605 guests
