| Author |
Message |
Bennyzarb
Joined: Tue Aug 24, 2010 12:22 pm Posts: 500 Location: north richmond
 Posted: Mon Jun 20, 2011 9:35 am |
Will I be able to fit 33s under my 92 swb Sierra I have 2in lifted ome springs snake racing extended shackles and am installing a 2 in body lift soon
Rusho
Joined: Sun Aug 02, 2009 11:30 pm Posts: 6501 Location: Northside, Brisbane
 Posted: Mon Jun 20, 2011 9:37 am |
Probably need a bit of guard clearancing also
_________________ Shep is a closet jimny lover!!!!
Sutho
Joined: Sun Jan 10, 2010 10:30 pm Posts: 735 Location: Scenic Rim, Qld
Vehicle: 1995 SWB Sierra TinTop
 Posted: Mon Jun 20, 2011 9:43 am |
and gears
_________________ 95 Sierra SJ70 TinTop
boostedbrick
Joined: Tue Jun 29, 2010 7:44 am Posts: 2003 Location: Brisbane
Vehicle: 2018 DMAX
Im not normally one to say this, but try searching mate.. Every thread you have in suzuki talk could have been answered by searching.
I ran, 2inch springs, 2inch shackels, 2inch body with a 1inch guard chop to fit 33's. Bump stop spacers would have been desirable/
Rusho
 Posted: Mon Jun 20, 2011 9:47 am |
Sutho wrote: and gears
That would also help
31zook
Joined: Tue Mar 24, 2009 10:30 pm Posts: 9242 Location: maito
 Posted: Mon Jun 20, 2011 10:06 am |
50mm BL, and a 4lb dumpy. X2 on searching
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Mon Jun 20, 2011 10:07 am |
31zook wrote: 50mm BL, and a 4lb dumpy. X2 on searching
Wanna help me fit some end of the year?
_________________ mlm
shep
Joined: Thu Mar 29, 2007 11:30 pm Posts: 14498 Location: Here there everywhere
 Posted: Mon Jun 20, 2011 10:08 am |
i have just fitted 33s. have 100mm spring/shackle lift on the front and 125mm
on the rear plus a 25mm body lift. also wt diffs with nt spacing, front diff moved about 50mm froward. and 6.5 trans case.
still need to do a lot of cutting especially on the front. i don't think there will be
much of the headlight bucket left when i am finished.
_________________ JEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEP
31zook
 Posted: Mon Jun 20, 2011 10:10 am |
SierraDan wrote: 31zook wrote: 50mm BL, and a 4lb dumpy. X2 on searching  Wanna help me fit some end of the year?
 you can borrow my hammer
SierraDan
 Posted: Mon Jun 20, 2011 10:19 am |
Saweeeeet
TryHard
Joined: Thu May 13, 2010 1:49 am Posts: 1041 Location: Perth
 Posted: Mon Jun 20, 2011 1:29 pm |
dont forget some 6.5 gears and some 26spine axles for the front
BlueSuzy
 Posted: Mon Jun 20, 2011 1:32 pm |
2" Body lift, 2" spring lift, pissorf the shackles.
samb0rg
Joined: Thu Oct 07, 2010 8:02 am Posts: 179 Location: 2450
 Posted: Mon Jun 20, 2011 2:29 pm |
shep wrote:  i have just fitted 33s. have 100mm spring/shackle lift on the front and 125mm on the rear plus a 25mm body lift. also wt diffs with nt spacing, front diff moved about 50mm froward. and 6.5 trans case. still need to do a lot of cutting especially on the front. i don't think there will be much of the headlight bucket left when i am finished.
I want to buy that Suzi.
BlueSuzy
 Posted: Mon Jun 20, 2011 2:36 pm |
ruf, corolla spring is in rear, 1" in total spring lift all round, 2"Bodylift, front is 30mm forward, Rear is 17mm rearward. Under size 33's.
 I miss her
sogone
Joined: Mon Oct 25, 2010 11:29 am Posts: 2070 Location: Darwin
 Posted: Wed Jun 22, 2011 8:57 am |
How did it go with rubbing Blue?
BlueSuzy
 Posted: Wed Jun 22, 2011 10:46 am |
Hammered all seams and headlight buckets. Rubbed alittle but didnt cut the tyres.
shep
 Posted: Wed Jun 22, 2011 10:47 am |
samb0rg wrote: shep wrote:  i have just fitted 33s. have 100mm spring/shackle lift on the front and 125mm on the rear plus a 25mm body lift. also wt diffs with nt spacing, front diff moved about 50mm froward. and 6.5 trans case. still need to do a lot of cutting especially on the front. i don't think there will be much of the headlight bucket left when i am finished. I want to buy that Suzi.
haha trust me ya dont
ajsr
Joined: Sun Dec 28, 2008 10:30 pm Posts: 3712 Location: melb
 Posted: Wed Jun 22, 2011 10:50 am |
BlueSuzy wrote:  ruf, corolla spring is in rear, 1" in total spring lift all round, 2"Bodylift, front is 30mm forward, Rear is 17mm rearward. Under size 33's.  I miss her
dont these tyres run at about 31.5" on a 33??
BlueSuzy
 Posted: Wed Jun 22, 2011 12:56 pm |
31.9
