It is currently Mon Oct 19, 2026 4:59 pm
Post Posted: Tue Jun 21, 2011 11:53 am
If you use a bearing puller to remove a bearing from a pulley, what do you use to push a new bearing in if you don't have a press?
2002 SWB GV
Lifted and Locked
vice & a couple of sockets....
http://www.outerlimits4x4.com/viewtopic ... 2&t=223612 Armsup
Post Posted: Tue Jun 21, 2011 1:02 pm
heat works good
Post Posted: Tue Jun 21, 2011 1:31 pm
Find something round and try to push the ring that is being fitted. e.g. outer bearing ring into hole, or inner bearing ring onto shaft. Reduces the risk of denting the balls during install.
Post Posted: Tue Jun 21, 2011 1:36 pm
Or - reverse the puller - you can use it in pretty much the same way you did to remove the bearings.
Vehicle: '92 Sierra
Post Posted: Wed Jun 22, 2011 1:22 am
Or you can get a cheap press from trade tools etc. That's what I used for gearbox and transfers.
Post Posted: Wed Jun 22, 2011 1:58 am
x2
Post Posted: Wed Jun 22, 2011 2:08 am
I want my old sig back :(
Post Posted: Wed Jun 22, 2011 2:32 am
I didn't realise the Puller can insert bearings as well. Thanks for that.
2002 SWB GV
Lifted and Locked
Post Posted: Wed Jun 22, 2011 4:21 pm
It really depends on the application - and in the case of a pulley (I believe you're specifcally asking about the idler pulley for the serpentine belt) - you can use the puller to "pull the pulley over the bearing" - you just need a heavy spacer so that the load of the center bolt is spread across the outer race, rather than being applied to the inner race and the balls.
Users browsing this forum: No registered users and 252 guests
