It is currently Tue Oct 27, 2026 11:08 am
Post new topic Reply to topic  [ 415 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10, 11, 12 ... 14  Next
Post Posted: Fri Jun 10, 2011 8:39 am
Sounds good. Cheers.
Post Posted: Sun Jun 12, 2011 10:34 am
I got a 92 swb vit with a g16a and a cracked manifold :( I don't suppose you've got extractors to suit?
My son has a 94 lwb vit (1.6 efi) with a v.noisy rear diff. Do you have a 2nd hand one perchance?
Thanks
Post Posted: Sun Jun 12, 2011 8:52 pm
Thanks
Cracked manifolds are common so demand for extractors is high. Can't help, sorry.
Been cleaned out of diffs too... Only got 5.12 fronts at the moment. :cry:
Post Posted: Sun Jun 12, 2011 8:55 pm
hey i was told to get on to your wreckers by a few people, what im after is a carby for a 1993 g13a the ones with the auto choke, and a rear door for a tintop let me know if you can help.
Post Posted: Sun Jun 12, 2011 9:35 pm
Got a carby here... Car ran fine but auto choke didn't work too well.
Only tintop doors I have are cracked and dented.
Post Posted: Fri Jun 24, 2011 10:50 am
Any lwb calipers?
Post Posted: Fri Jun 24, 2011 11:02 am
zooky08 wrote:
Any lwb calipers?
Nope.. No vented discs either. :cry:
Post Posted: Fri Jun 24, 2011 11:06 am
want33s wrote:
zooky08 wrote:
Any lwb calipers?
Aww will lwb Sierra calipers work for a disc conversion?
Post Posted: Fri Jun 24, 2011 11:29 am
zooky08 wrote:
want33s wrote:
zooky08 wrote:
Any lwb calipers?
Sierra SWB & LWB are same calipers from 1.0 to 96. Dunno if they'll suit your application... What conversion do you have?
Post Posted: Fri Jun 24, 2011 5:33 pm
want33s wrote:
zooky08 wrote:
want33s wrote:
zooky08 wrote:
Any lwb calipers?
Ive got bent non handbrake kit
I could always just run the portioning valve
Post Posted: Sun Jun 26, 2011 2:36 am
hey want37s, got any freewheeling hub allen bolts & cone washers? :lol:
Vehicle: 2011 Jimny
Post Posted: Sun Jun 26, 2011 2:56 am
Have you got any more vit headlights I'm chasing the left one and postage to 6027
Jimny's really do ROCK
Post Posted: Sun Jun 26, 2011 5:03 am
I think I've got a problem with my autochoke or idle.. just wont idle in the cold.
Any chance you've got a good nic, working carby for a g16a?
Post Posted: Mon Jun 27, 2011 9:05 am
Hey Jas,
Do you have a G16B oil pickup? Doin swap into my Sierra but when I bought the rebuilt short motor there was no sump/pickup included.
Post Posted: Mon Jun 27, 2011 8:53 pm
Yeah Gus how many you want?
Sorry no LH at the moment.
Sorry Sam I don't have any Vit carbies.
Jasen wrote:
Hey Jas,
If you are putting a G16B in a Sierra you'll want a G13 Sierra sump and pickup with the end sleeved so it fits the hole in the block and the stabiliser tab thing relocated.
I have a few Sierra sump/pickups here.
Post Posted: Mon Jun 27, 2011 9:19 pm
want33s wrote:
Jasen wrote:
Hey Jas,
I was planning to use half the g16 pickup (ie the half that fits into the block/oil pump) then brazing on the g13 pipe and seive. I already have the 1.3 pickup complete. So I assume you don't have a 1.6 pickup?
cheers
Post Posted: Mon Jun 27, 2011 10:14 pm
Jasen wrote:
want33s wrote:
Jasen wrote:
Hey Jas,
cheers
No G16 pickups for sale at the moment.
I do have one in a Baleno but haven't got the engine out of it yet.
Post Posted: Tue Jun 28, 2011 4:59 am
clutch cable for a 92 swb carby vitara? or somewhere that has new ones for a reasonable price. Aparently the carby model cable is different to the EFI.,, is that correct?
Cheers Andy
Post Posted: Tue Jun 28, 2011 6:24 am
Cheers Andy
None of the cables I have are what I'd call like new...
Try www.suzistore.com.au for a new one.
Post Posted: Tue Jun 28, 2011 6:48 am
any decent engine mounts for a g16b (swb)? mainly passenger side but drivers would be good.
Mitch
Post Posted: Tue Jun 28, 2011 10:06 am
Mitch
The rubber bits?
Not worth buying second hand. New ones are cheap enough.
Post Posted: Tue Jun 28, 2011 1:29 pm
want33s wrote:
Mitch
The rubber bits?
not sure, the entire thing i guess. yeah was thinking that, just thought i would ask anyway.
thanks
Vehicle: 96 LWB Vit
Post Posted: Thu Jun 30, 2011 4:03 am
need 2 x front wheel hubs (the bits with the wheel studs in them) in good nick.
Mine is a 96 LWB although they all should be the same.
Posted to 4110.
Cheers.
Buddies
I can't leave well enough alone....
Post Posted: Thu Jun 30, 2011 10:21 am
Posted to 4110.
Cheers.
Sorry mate... What is it with these Vit hubs?.. Had heaps of demand for them recently.
Vehicle: Daisy
Post Posted: Thu Jun 30, 2011 10:30 am
Hey Jas, just checking the price and availability on a VSS cluster or even just the part required for the conversion of a 1.6 into a sierra.
Post Posted: Thu Jun 30, 2011 10:37 am
keen to diy? http://auszookers.com/index.php?name=Fo ... ic&t=10121
Vehicle: Daisy
Post Posted: Thu Jun 30, 2011 10:43 am
Yes but just trying to find out what one would be worth that's plug n play.
I'm not scared at all to DIY it.
EDIT: Also thanks for the link, hadn't gone searching for it yet.
Vehicle: 91 swb vit 5"lift 31's.
Post Posted: Fri Jul 01, 2011 7:42 am
hey mate got any cheap and nasty rear bumpers? i have a swb vit 1991 i just need the top half so gonna chop it up..
Post Posted: Fri Jul 01, 2011 9:41 pm
Rear bars go real quick for some reason... :?
Vehicle: stock yellow vit.
Post Posted: Fri Jul 01, 2011 10:46 pm
im after a rear diff for my 89 swb got any?
Users browsing this forum: No registered users and 66 guests
