[ 7 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
Philbilly
Joined: Wed May 11, 2011 11:41 pm Posts: 84 Location: SWR
 Posted: Sun Jun 26, 2011 7:48 am |
Hi,
been looking into some 50 mm spring spacers and confused about one thing. Can I put 50 mm spacers in both the front and back? Or am I spose to put 25mm in the front and 50 mm in the back?
Cheers,
Phil
Taylor74
Joined: Fri Dec 24, 2010 10:26 am Posts: 198 Location: Perth WA
 Posted: Sun Jun 26, 2011 7:55 am |
Assuming you are talking about Vitara coil spacers, 25 mm front will give 50mm lift and 50mm in the rear to give the same result. The front coils work on a different ratio due to the spring being in closer. Rough way of a lift but yes it works.
Think about getting some OME shocks for the front as std struts tend to have a habbit of topping out with 50mm of lift, they are to my knowledge the longest replacement strut on the market unless someone can correct me.
_________________ Suzuki is my way of life.
Vits93
Joined: Mon Jul 05, 2010 11:42 am Posts: 233 Location: Nowra NSW
 Posted: Sun Jun 26, 2011 7:57 am |
If its a vitara your talking about then yes you put half in the front of what your putting in the back because of the ifs.
Philbilly
 Posted: Sun Jun 26, 2011 9:26 am |
Yeah, talking about a Vitara- I forgot to mention that...sorry. Thanks for the info.
Yep, a bit of a short cut for a lift but just want a tad more height. Pretty happy with the stock suspeion set up I have- for now anyway.
Thanks again.
Cheers,
Phil
Brett
Joined: Tue May 27, 2008 11:30 pm Posts: 1791 Location: Central coast NSW
 Posted: Sun Jun 26, 2011 9:48 am |
if you buy a full kit it will have the right ones in it to match front and rear
this is the kit i am using from low range. comes with rear, front and front shock spacers for a 50mm lift
Philbilly
 Posted: Sun Jun 26, 2011 12:55 pm |
Thanks Brett, I spotted those at Lowrange. Seem good quality.
Cheers,
Phil
zuk94
Joined: Sat Sep 13, 2008 11:30 pm Posts: 193 Location: brisbane
Vehicle: 94 Vitara LWB
 Posted: Mon Jun 27, 2011 7:30 am |
What others have said is generally true and accepted , but I have a steel ARB bar on mine and have 30mm spacers in the front and 40mm in the rear and it looks right . So maybe the half at the front rule is for standard applications .
[ 7 posts ] |
Users browsing this forum: Google [Bot] and 166 guests
