It is currently Tue Oct 13, 2026 8:10 am
Vehicle: Toyota Hilux
Post Posted: Sun Jun 19, 2011 11:05 am
I own 2 Maruti utes, a 91 and a 92. Today i tackled a simple task of replacing the rear bearings on the 92 cause it had a bad vibration. All started well until I realised I have to disconnect the brake lines get the axles out. No biggy, so once that was done I happen to find the bearings were fine. Ok must be in the diff. Yep sure was, the bearings closer to the tail shaft are flogged out. I just pulled the other diff out of the 91 so I can get the 92 going. Wrong. The bloody diff inners are different sizes, same axle splines 26. Worked out also that the 92 has a transfer handbrake and has early 1.3 NT diffs and the 91 has 1ltr WT diffs and a drum style handbrake and I thought they were the same. So now I have 2 Marutis off the road, bummer. Still not sure how to pick the difference yet between NT 1.3, NT 1ltr and WT 1.3 and WT 1ltr.
Post Posted: Sun Jun 26, 2011 10:19 am
Update, ok now I have realised that I actually have 2 x 91 Marutis. One is a wide track and the other is a narrow track. Strange really as I thought coming out the same year they would be very much the same. I guess I wont need those WT axles after all jono from Berkley, your off the hook dude.
Post Posted: Sun Jun 26, 2011 10:31 am
No standard 91 Maruti will be a WT. They didn't appear until 94.
Post Posted: Sun Jun 26, 2011 11:58 am
Comfirm its a wide track, not sure of its history though the diffs are wider and has the flared factory guards and looks like its never been pulled apart. Im not convinced in what you saying Fatzook.
Vehicle: Sj70 tintop
Post Posted: Sun Jun 26, 2011 12:42 pm
june 93 was the last of the n/t marutis were built.
Sj70 tintop
Post Posted: Sun Jun 26, 2011 3:57 pm
Yeah cool. Its a grey area as some people read off the build date and others the complied date. Either way, a 91-92 maruti is NT 1L.
Post Posted: Sun Jun 26, 2011 11:50 pm
It might be a NT body but its got WT axles for sure, why I dont know. Ill try and post a pic soon and you can make your own mind up.
Post Posted: Mon Jun 27, 2011 3:16 am
Guess someone swapped them already :D Good news!
Post Posted: Mon Jun 27, 2011 6:12 am
ya saves u the hassle haha :)
Oi Fat zook how hard is it to put WT axles onto a Maruti lwb Ute ?
is it just a matter of changing the perch's on the WT axles ? and the Transcase Flanges ? also how would the Diff Ratio's go witha 30s
and the 1 L engine .. sorry if im highjacking kinda same subject
Post Posted: Mon Jun 27, 2011 6:32 am
Yes just move the perches. Depending on what springs you have you may need to look at bumpstop spacers. Also pays to check your brake line length, although this isn't usually an issue.
As for the diff ratios, Maruti is 4.1, and WT is 3.7, so its gonna hurt you pretty bad. If going to 30-31's you could look for some 4.6 vitara ratios and slot them into the WT carriers and that should get you moving along nicely.
Flanges should be interchangable.
Post Posted: Mon Jun 27, 2011 7:09 am
Thanks for the info should i just change the flages on the 1 L transcase when he puts reduction gears in .. thats another story haha
also wouldnt it be better puttting something like
4.57 Ratio Nitro Gear into the diffs ?
might make my own thred about this
Post Posted: Mon Jun 27, 2011 7:11 am
TryHard wrote:
Thank4.57 Ratio Nitro Gear into the diffs ?
Why? Costs you more money, and is harder to get replacements for. And its almost the same ratio. :crazy:
Users browsing this forum: No registered users and 208 guests
