It is currently Mon Oct 12, 2026 10:26 am
Post Posted: Tue Jun 28, 2011 1:14 am
Guys i'm going to onesteel shortly to get some pipe/tube and bends for my rear bar and sliders. My question is as follows:
I'm going to be using seamless black pipe what size should i make the rear bar out of and also what wall thickness?
What would be strong enough
What have other people used
I will be using he 90degree and 45 degree bends to get the curves
I will be making a basic rear bar with recovery points and a intergrated reece tow hitch, and LED tail lights.
Also will be putting a swingaway tyre carrier and jerry can holder
Conrad
EDIT:
Going to copy this bar below should be good:
Conrad
I HATE CYCLISTS!!!
Post Posted: Tue Jun 28, 2011 1:25 am
32nb med black works for me
Post Posted: Tue Jun 28, 2011 1:26 am
What wall thickness is that? And what is the OD approx.
Conrad
I HATE CYCLISTS!!!
Vehicle: 2018 DMAX
Post Posted: Tue Jun 28, 2011 1:31 am
32nb medium is around 42.5OD 3.2mm wall
Post Posted: Tue Jun 28, 2011 1:50 am
32nb is the popular choice
Standard weight seamless is 3.5mm thick, Medium CHS is 3.2mm thick
Seamless is not a structural pipe, CHS is and will likely cost less for a guy off the street
32nb seamless Xtra Strong is 4.85mm thick, sch160 is 6.35, if you can get some of that for your sliders they might cop the hits better
Post Posted: Tue Jun 28, 2011 2:02 am
cheers guys i'll go and get me some and try to make a start.
Thanks
Conrad
I HATE CYCLISTS!!!
Post Posted: Tue Jun 28, 2011 2:41 am
how much does the stuff cost?
Post Posted: Tue Jun 28, 2011 4:45 am
i can get the 32nb with a 3.2 wall for $56.76 for 6.5 metre length from my local scrap metals man (J&P Metals Bunbury)
Onesteel do the thicker pipe for $78 per 6.5m length with a wall thickness of 4.85mm.
Bends are between $2.5-$4.5 per bend
A 6.5m length will do my rear bar and my sliders hopefully.
Conrad
I HATE CYCLISTS!!!
Post Posted: Tue Jun 28, 2011 4:48 am
Think youll find this is 6m
Post Posted: Tue Jun 28, 2011 5:27 am
yep mine is from 32nb. One thing is the bends dont match perfect, but good enough.
Jeez you are going to be busy
Users browsing this forum: No registered users and 346 guests
