It is currently Tue Jul 28, 2026 1:09 pm
Vehicle: Sj70 tintop
Post Posted: Wed Jun 29, 2011 11:57 am
cant find anyone who supplies them, but can get them made cheap,
anyone have the length/diameter etc of them to give the guys the measurements to knock them up?
cheers
Sj70 tintop
Post Posted: Wed Jun 29, 2011 8:20 pm
Carol springs at wacol QLD
they just fab new ones up.. I got get u the dimensions for u this avo but I'm more than possitive someone else on here will tell u before then..
Post Posted: Wed Jun 29, 2011 9:53 pm
yeah they are the blokes who im using to fab them, they just need the size.
yeah chuck me the size when ya get them!
cheers
Sj70 tintop
Post Posted: Thu Jun 30, 2011 12:23 am
Just note, when I got them to make me new ones for my LJ's, they are in 1.3 Sierra U-bolt size bar. The 1L/LJ size bar is smaller than anything they keep on shelf. It's no biggy, just had to drill out the U-bolt plates ever so slightly.
Clearance Hole Technology :P
Post Posted: Thu Jun 30, 2011 5:50 am
I've only got rear ones.. I got 4 new front ones by accident, which I gave to 3cyl.. He will have dimensions for u..
rears are 10mm thick.
140mm height with 80mm of thread
width from centre to centre is 80mm
Hope that helps
Post Posted: Thu Jun 30, 2011 8:27 am
cheers
that should be fine!
Sj70 tintop
Post Posted: Thu Jun 30, 2011 8:58 am
I manage to draw a pic of the size with those dimensions :D
Post Posted: Thu Jun 30, 2011 9:04 am
do you reckon the fronts are the same?
should i just get 1.3 u bolts and just re drill the plates?
they didnt have the sizes of any sierra u bolts.
Sj70 tintop
Post Posted: Fri Jul 01, 2011 3:53 am
carols springs has 1liter u bolts in stock, they are just under the lj parts listing.
brad your measurements are pretty much spot on, but the front has 2 different size bolts, the measurements you mentioned and one slightly longer each side.
cheers
Sj70 tintop
Post Posted: Fri Jul 01, 2011 5:09 am
cheers
yea cause off where they sit.. 1 is alittle wider aswell if I rember right to suit the short side
Users browsing this forum: Google [Bot] and 330 guests
