| Author |
Message |
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Tue Jun 28, 2011 9:10 pm |
I'll suss out the barrel too then.
_________________ mlm
joe5701
Joined: Mon May 30, 2011 7:43 am Posts: 241 Location: narromine
 Posted: Tue Jun 28, 2011 9:19 pm |
if its in the barrel, when it cuts out you will have no reds on the dash.
SierraDan
 Posted: Tue Jun 28, 2011 9:31 pm |
Not the barrel then.
shep
Joined: Thu Mar 29, 2007 11:30 pm Posts: 14498 Location: Here there everywhere
 Posted: Tue Jun 28, 2011 9:40 pm |
joe5701 wrote: if its in the barrel, when it cuts out you will have no reds on the dash.
yeah, it behaves like a dead fuse link.
_________________ JEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEP
royce
 Posted: Tue Jun 28, 2011 10:29 pm |
test light will tell you enough, you want the light to light up heaps on the positive terminal and flash when connected probe to positive, clip to negative
easy thing to do first is pull a lead and check for spark
I am guessing a module or coil breaking down from heat, once it cools down some off it goes again
joe5701
 Posted: Tue Jun 28, 2011 10:31 pm |
I am guessing a module or coil breaking down from heat, once it cools down some off it goes again[/quote]
x2
SierraDan
 Posted: Wed Jun 29, 2011 7:16 am |
Okay. Just got home and had a look.
It lights up real bright as you said. and clip on neg and probe on positive it sort of flickers in relation to revs its noticeable if you look at it hard enough but i wouldnt say its switching on off on off.
joe5701
 Posted: Wed Jun 29, 2011 7:20 am |
thats what it should do, but do you still have power there when it dies?
SierraDan
 Posted: Wed Jun 29, 2011 7:26 am |
i cant get it to die.. it really only does it when im driving. and when i get home and have a go at fixing it.
royce
 Posted: Wed Jun 29, 2011 10:28 am |
nope you gotta do it when its broken, no point trying to fault find when the fault isnt present
joe5701
 Posted: Wed Jun 29, 2011 10:34 am |
keep a testlight in the car, next time it die's check coil positive if it's good clip the clamp on the test light to coil negative and the probe end to battery positve, wind it over as if you are trying to start it, if the test light flickers really fast get a new coil, if not get a new ignition module.
SierraDan
 Posted: Wed Jun 29, 2011 10:56 am |
whats the ignition module?
royce
 Posted: Wed Jun 29, 2011 10:58 am |
its inside the dizzy, converts the magnetic pulse from the reluctor in the dissy to a switched signal to trigger the coil
SierraDan
 Posted: Wed Jun 29, 2011 11:01 am |
Ah okay. Shall test again tomorrow.
Cheers.
dawsey
Joined: Fri Mar 19, 2010 10:30 pm Posts: 218 Location: perth
 Posted: Thu Jun 30, 2011 9:23 am |
how did it go dan..interested in the outcome myself.
SierraDan
 Posted: Thu Jun 30, 2011 9:28 am |
Ended being a clip connector thing was had it and sometimes didnt give a connection.
When it died i traced it back to there. limped home and hard wired it and the rest of the wiring near by so everything was fresh and strong. gave everything a wd-40 clean and rub with emery cloth. Good as new!
Thanks for the help guys.
atari4x4
 Posted: Thu Jun 30, 2011 9:33 am |
SierraDan wrote: Ended being a clip connector thing was had it and sometimes didnt give a connection.
what clip connector thing where, was it on the valve cap?
SierraDan
 Posted: Thu Jun 30, 2011 9:37 am |
atari4x4 wrote: SierraDan wrote: Ended being a clip connector thing was had it and sometimes didnt give a connection.
Thanks for the help guys. what clip connector thing where, was it on the valve cap?
In line on the positive side to the coil. a quick connector thing.
JrZook
 Posted: Thu Jun 30, 2011 10:03 am |
SierraDan wrote: JrZook wrote: Start off by checking all the wiring and connectors to the dizzy and coil. Pull em apart and clean them. Check all the earth's as well.
Run the thing at night and have a look under the bonnet in the dark and check for sparks around the dizzy and coil. I've checked all the connections they're all good. So check for sparks coming from the insulation? I did get an awesome shock the other week..
_________________ Lil Foot!
SierraDan
 Posted: Thu Jun 30, 2011 10:04 am |
JrZook wrote: SierraDan wrote: JrZook wrote: Start off by checking all the wiring and connectors to the dizzy and coil. Pull em apart and clean them. Check all the earth's as well.
Haha yeah. This one tricked me! Taking the test light with me so i had it while it was dead helped. Rather than having it at home.. running fine.
