| Author |
Message |
Philbilly
Joined: Wed May 11, 2011 11:41 pm Posts: 84 Location: SWR
 Posted: Sat Jul 02, 2011 1:37 pm |
For a Vitara, what tyre pressure you guys are running in your MT tyres? I realise this is a little open ended as there are so many different terains etc, but for just general driving around the streets and a short offroad stint, what pressure would you run?
Cheers,
Phil
alien
Joined: Wed Mar 24, 2010 10:30 pm Posts: 16343 Location: Perth
 Posted: Sat Jul 02, 2011 1:57 pm |
what size?
FullyZooked
Joined: Mon Oct 25, 2010 9:01 am Posts: 1009 Location: Bendigo
 Posted: Sat Jul 02, 2011 2:07 pm |
In my g16a powered Vit with maxxis bighorns 235/75's I run 40psi for normal road driving. I only run this when doing highway driving or I run out of boondi with any lower pressures.
Offroad where the car spends 80% of it's life is between 8-15psi depending on terrain.
_________________ Built Suzuki's shall reign Victorious.
alien
 Posted: Sat Jul 02, 2011 2:26 pm |
40PSI!!!!!! WTF?!
i run 31s on my sierra - 26psi front and 22psi rear (this is with Kumho KL71)... with BFG KM2 i run 24psi front and 20 rear... with simex ET i ran 20 front and 18 rear.
offroad the KL71s get 9psi, the KM2 get 8psi and the simexs got as low as i dared which was 6psi.
theres a tyre placard inside the drivers door (sometimes) - this should give you a PSI for standard sized tyres, and is a good place to start no matter what size you're running.
mongrelzook
Joined: Mon Jun 27, 2011 11:55 am Posts: 144 Location: brisbane
Vehicle: 96 sj70+80 tintop sierra
 Posted: Sat Jul 02, 2011 2:30 pm |
I was running 32psi all round and thought was bit rough on 31s put it down to about 26 and seems ok. Can understand winding it up abit for highway thought 40 is bit much.
MacDaddy
Joined: Thu Mar 26, 2009 10:30 pm Posts: 10453 Location: Perth, Australia
Vehicle: Jeep
 Posted: Sat Jul 02, 2011 2:31 pm |
alien wrote: 40PSI!!!!!! WTF?!
Yep, check the tyre placard on the door recess, run them at that first and see how you go... from memory i think its 24psi...
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Sat Jul 02, 2011 2:54 pm |
I run 20-25 on road.
7-10 offroad.
_________________ mlm
atari4x4
 Posted: Sat Jul 02, 2011 4:46 pm |
my 31" MT/R's run at 29psi cold on the road & usually between 12-10psi warm off road, will usually have another check in the morning for cold pressures if doing an overnighter/weekender.
Brett
Joined: Tue May 27, 2008 11:30 pm Posts: 1791 Location: Central coast NSW
 Posted: Sat Jul 02, 2011 8:48 pm |
31x11.5 claw on a 7 inch rim on a 1.6 4 door vitara.
on road 30 -34
light track work 20
hard tracks/ beach work 6- 12.
royce
 Posted: Sat Jul 02, 2011 9:59 pm |
I still cant believe people over inflate their tyres so much
shep
Joined: Thu Mar 29, 2007 11:30 pm Posts: 14498 Location: Here there everywhere
 Posted: Sat Jul 02, 2011 10:12 pm |
royce wrote: I still cant believe people over inflate their tyres so much
dont they ever look at there tyre placards? i would hate to have to stop in a hurry
if driving a suzuki that has 40psi in the tyres.
_________________ JEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEP
SuziBlu
Joined: Mon Sep 14, 2009 11:30 pm Posts: 4268 Location: Eyre Peninsula
 Posted: Sat Jul 02, 2011 11:08 pm |
40 is a pretty terrifying pressure imo in a little light zook. even up 30ish is frightful.
I run claws, 31s at 22 up front and 20 rears, thats in me lwb maruti.
Any more and its getting to harsh on the blacktop, and on the dirt roads, even that is a bit high.
_________________ Bad decisions make good stories.
boostedbrick
Joined: Tue Jun 29, 2010 7:44 am Posts: 2003 Location: Brisbane
Vehicle: 2018 DMAX
 Posted: Sat Jul 02, 2011 11:12 pm |
shep wrote: royce wrote: I still cant believe people over inflate their tyres so much dont they ever look at there tyre placards? i would hate to have to stop in a hurry if driving a suzuki that has 40psi in the tyres.
The tyre wear with 2inchs of tread on the road would be awesome...
MT117 extremes, 19 all around
Goodyear wranglers 22 all around.
ollies
Joined: Wed Oct 13, 2010 8:42 pm Posts: 208 Location: pakenham
Vehicle: vitara
 Posted: Sat Jul 02, 2011 11:18 pm |
235/75/15, federal couragias, i run 30psi on road and 15psi off, on a lwb vit.
smiffkid
Joined: Fri Aug 13, 2010 12:55 pm Posts: 3266 Location: perth wa
 Posted: Sat Jul 02, 2011 11:30 pm |
run 25 all round in my 31s, both my xterrains and claws,
dont even run 40 in nissans or toyotas, normally between 32 and 34
_________________ dodgy brothers mechanical
FullyZooked
 Posted: Sat Jul 02, 2011 11:39 pm |
I will give 30 psi a go today as we have a 4x4 run out of town.
As for running higher pressures I think I stated why, but mind you i'll give 25-32 for on road a go.
So much anger this morning geez...
Philbilly
 Posted: Sun Jul 03, 2011 12:02 am |
Thanks everyone for the info
alien wrote: what size?
235/75/15 mate.
I'd read on other forums about these heavy (high) tyre pressures, and I know from running around in my fuel guzzling Jeep that 40 pounds would near throw me out the front window- or at least compress a few disk in my back...
I was hoping to hear around 20 lb was right, as I'm a lazy bugger and I'd like to drive straight from the road onto the sand with no adjustment. Though I know a lower setting again would be better for the beach.
So at say 20 lb, would road ware be pretty even? Or is it wiser to opt for 25 lb or so?
I plan to rotate them every 10,000 kays or so.
Cheers,
Phil
alien
 Posted: Sun Jul 03, 2011 12:39 am |
you need to test it... drop pressure and then roll over some talcum powder on the driveway to see how much tyre is contacting the road... i usually have about 1" of the tread face each side not touching and this proves to be right for the 4psi rule (after a highway drive they go up 4psi).
the softer you go the more wallowy it will feel in corners too, as the sidewalls will flex more.
Scrawny
Joined: Tue Jan 29, 2008 10:30 pm Posts: 10528 Location: Brissie
 Posted: Sun Jul 03, 2011 1:40 am |
I run 40psi in my Prado. I ran 20psi in my Sierra on road and 10 offroad. I run 50psi in my work van (current Hiace)
lump_a_charcoal
Joined: Wed Feb 28, 2007 10:30 pm Posts: 4454 Location: Botany, NSW
Vehicle: MY2019 Jimny
 Posted: Sun Jul 03, 2011 2:44 am |
I used to run 24psi on road, and 4-8 off road.
31 inch baja claws.
MacDaddy
Vehicle: Jeep
 Posted: Sun Jul 03, 2011 4:58 am |
Philbilly wrote: Thanks everyone for the info alien wrote: what size? 235/75/15 mate. I'd read on other forums about these heavy (high) tyre pressures, and I know from running around in my fuel guzzling Jeep that 40 pounds would near throw me out the front window- or at least compress a few disk in my back... I was hoping to hear around 20 lb was right, as I'm a lazy bugger and I'd like to drive straight from the road onto the sand with no adjustment. Though I know a lower setting again would be better for the beach. So at say 20 lb, would road ware be pretty even? Or is it wiser to opt for 25 lb or so? I plan to rotate them every 10,000 kays or so. Cheers, Phil
Just dont forget, running a tyre under inflated on the road, will build up more heat than normal pressure, and shorten the life of the tyre... i would strongly suggest running the tyre placard pressure for onroad !
Tyre fitters seeem to think that all tyres should have 32psi in them, when i had my AT's fitted, the ride was very harsh, the tyres would skip over rail lines and crab sideways, checked tyre pressure, 32psi...
Zooks are Light, they dont need anything over 25psi !
I know he might be a bit tired of repeating himself, but Greg Dixon is the tyre man...
