It is currently Tue Jul 28, 2026 1:06 am
Vehicle: 08 Grand Vitara Pres
Post Posted: Mon Jul 04, 2011 4:16 am
ok kids
just put M13A VVt engine / gearbox into a 98 jimny.
problem I have is that my jimny has manual t-case and new wiring and gear is auto t-case.
some how I am missing my 4wd Controller module off the old system (G13BB) so Im looking for a photo of one so I can hunt around my bits and see what I can find.
it sits up under the dash with the body module. from what I remember it has 4WD controller assy on it
Post Posted: Mon Jul 04, 2011 8:29 am
Dont think the older system had a 4wd module mate...
But your more then welcome to come poke your head under my dash at any stage
Post Posted: Mon Jul 04, 2011 8:31 am
Bingo.......
Post Posted: Mon Jul 04, 2011 8:34 am
what controls the solenoid for the auto locking hubs?
Post Posted: Mon Jul 04, 2011 8:36 am
u got manual transfer case, just get manual locking hubs and forget about the auto buttons and bits :helloo:
Post Posted: Mon Jul 04, 2011 8:39 am
the 4wd switch from memory....
Post Posted: Mon Jul 04, 2011 8:44 am
ok so where is the switch? on the transfer case.
Post Posted: Mon Jul 04, 2011 9:04 am
yep, i think it's the only one....
Post Posted: Mon Jul 04, 2011 9:23 am
ok.. im very confused now why its not working.. ARGH
Post Posted: Mon Jul 04, 2011 9:46 am
Wana come and compare the 2??
I would say you have pulled all the wiring out of the engine bay and put in a later model loom?? When emgine conversion was done.. Including all solenoids and fuse boxes and relay boxes?? Then put in the vvt one loom??
The switch on the transfer switches a vacuum solenoid which in turn puts vacuum to the hubs to make them engage.
2 options as I see it..
Rewire it all in with a vac solenoid etc... Not to difficult to do..
Or
Go to manual hubs
Post Posted: Mon Jul 04, 2011 9:55 am
ill finish the body mods and come visit you! thanks mate
Post Posted: Mon Jul 04, 2011 9:57 am
Body mods?? :blink:
Post Posted: Mon Jul 04, 2011 10:11 am
yeah Im in the middle of cutting the flares off and making it look more japanese. getting rid of the plastics.. making it clean with just a 65mm rubber edging.
makes it look a lot higher off the ground and gives more clearance in the arch.
Im about to try some 30" wranglers on it to see how it goes. (standard shocks)
Post Posted: Mon Jul 04, 2011 12:16 pm
build tread??? :D be sure to take some pics of the process :wink:
Post Posted: Mon Jul 04, 2011 12:24 pm
x2 cus i was think about going down that path, getting ick of those shitty plastic bits always falling off :x
Post Posted: Tue Jul 05, 2011 7:11 am
i have taken photos. I might put something up on it.. ;)
oh I fixed the problem with the 4WD.. I found that the vacuum hose was split under the guard.. now it works..
but the 4wd lights are flashing and warning lights going off everywhere.. need to figure out how to stop them.
Post Posted: Tue Jul 05, 2011 8:38 am
Woukdnt mind catching up and having a gander at the conversion mate.
Post Posted: Tue Jul 05, 2011 8:41 am
I'll bet you there's alot of connection's that want sig's that don't have it, also you may need to go through & clear/reset code's.....
Post Posted: Tue Jul 05, 2011 10:53 am
how do you do a master reset
Post Posted: Wed Jul 06, 2011 6:12 am
SDT, Suzuki Diagnostic Tool. or a good scan tool, most won't do much other than read code's....
Post Posted: Thu Jul 07, 2011 10:45 am
so I cant do it myself. dam.
Post Posted: Thu Jul 07, 2011 12:23 pm
isn't the only input signal to the 4wd module that makes the 4wd light flash from the vacuum sensor near the solinoids? I'm sure it is
all jimny's have a 4wd module in the early ones it will be above the fuse box screwed to the panel the speaker is mounted to its a black box wish i had a photo for you.
you should be able to fix the flashing 4wd light by making sure there is no vacuum loss in the hub locking system. the module will apply vacuum to the locking or unlocking circuit (depending what your doing) for 10 or 15 seconds) than vents the system. the sensor measures the locking circuit only(from memory). a genuine suzuki manual explains this very well also thinking out of the box will help you understand this system.
Post Posted: Thu Jul 07, 2011 11:49 pm
cheers gman Ill look for more leaks and read my manual.
I thought maybe it had something to do with the 4WD being engaged on the tcase but the buttons not pressed on the centre consule.
Users browsing this forum: Google [Bot] and 456 guests
