It is currently Fri Nov 13, 2026 12:12 pm
Post Posted: Tue Jul 05, 2011 2:59 am
4x4zook PM'd me asking about the late model g16 dizzy. I figured i'd post up the info I have in case someone else was chasing it. AFAIK all X-90s had this engine, as well as some late model 16v Vits.
This is a pic of the module out of the dizzy. The big transistor with the mitsubishi logo on it is the ignitor.
This is the wiring diagram of the dizzy. The extra info is from my Megasquirt install, but it should be the same for any aftermarket ECU.
The only thing here that might need clarification are the Megasquirt labelled items. "Megasquirt DB37 pin24" is the output from the cam position sensor, and "Spark output from Megasquirt" is the signal from the ECU that says "Hey Mr. Coil fire NOW!!!"
Post Posted: Tue Jul 05, 2011 6:07 am
I've got one of these dizzys if someone's chasing one
Post Posted: Tue Jul 05, 2011 10:31 am
ive done exactly what that diagrm says and still no spark i got the 2 ign wires connected 1 has 12v but the other has 3v with ignition "on". should it have 12v and any idea y it would only have 3?
Post Posted: Tue Jul 05, 2011 12:08 pm
it has 2 blu/blks. how do ya know wich 1 is 12v ignition and wich ones earth?
Post Posted: Tue Jul 05, 2011 12:12 pm
This should go into the good tech section
 Profile YIM
Post Posted: Tue Jul 05, 2011 12:43 pm
Have a look at the diagram again. Pin number is right next to the colour. Pin 1 is ground pin 2 is 12V ignition.
Don't mean to sound rude but from your previous posts I'd suggest to just slow down the connecting wires part a little until you digest all the info given and try to ask questions if your not 100% sure.
Automotive electronics are very rugged and can handle what a bit of abuse but they are not completely indestructible and damage can be easily done is not wired in the correct polarity.
Dan
Lil Foot!
Post Posted: Tue Jul 05, 2011 12:49 pm
Look closely... One is blu/blk, one is blk/blu...
I want my old sig back :(
Post Posted: Tue Jul 05, 2011 12:55 pm
sorry im being so annoying but im itchin to get this thing goin. ive been through the rigs of auzookers thread a million times and cant wait to hopefully build something like u guys own XD just being very impatient. sorry and thanx for all ur help.
Post Posted: Tue Jul 05, 2011 1:56 pm
I've noticed that you seem to be very keen to get your beast going but impatience cost more time and money in the long run especially with electronics! I'm not sure how available EFI bits like computers and ignition coil igniters and what the cost of such items are where you are from but they do fetch a few penny's around the wreckers here (if they have them).
You will get it going eventually and from what it looks like with your ECU wiring mistake you have possibly gotten off lightly so far.
Like I said before, just take a few more minutes to understand the info and start writing down or drawing wiring diagram from the available info. When you have it all connected up double check it again and be confident before you switch the power back on.
Dan
Lil Foot!
Users browsing this forum: Google [Bot] and 76 guests
