It is currently Tue Oct 13, 2026 6:57 am
lesspostingmorewheeling
Post Posted: Mon Oct 13, 2008 3:32 am
i'm gonna be using reduction gears in my zook and i've heard a lot of stories of people breaking cases/gears/mounts so i want to brace it so i don't have to worry about that happening
what can i do to stop that from happening?
Post Posted: Mon Oct 13, 2008 12:40 pm
how much reduction are you running?
Post Posted: Mon Oct 13, 2008 2:36 pm
i'm pretty sure its 6.5:1
Vehicle: MY2019 Jimny
Post Posted: Mon Oct 13, 2008 2:49 pm
There are a couple of options - Get a rock toy ring from someone here or on Outers, then weld it ontp some other braces..
Or, buy a Might Kong bracket. That is the most expensive option at the moment because the dollar is so bad against the greenback.
Post Posted: Mon Oct 13, 2008 3:22 pm
Mines been fine with 33"s rear locker and rock hopping!
Post Posted: Mon Oct 13, 2008 3:28 pm
Your brackets aren't stock though are they?
Post Posted: Tue Oct 14, 2008 2:27 am
i just ordered a roktoy ring is anyone on here using one?
Post Posted: Tue Oct 14, 2008 3:01 am
I am. Welded the stock arms to it, and braced the stock arms. It's a bastard to fit in if you have no body lift. A little info here
Post Posted: Tue Oct 14, 2008 3:02 am
My stock brackets are alittle reinforced for twist....Still original rubber mounts, Still original holes in transfer for bolts etc. Your on 31's?? You should be o'lright.
Or am i running a risk... :oops:
i'm lucky i got pleanty of body lift
how are you planning on bracing it to the standard arms?
Post Posted: Tue Oct 14, 2008 3:05 am
i got worried when i talked to a guy who installs rockhoppers today and he said that its not if i'm gonna break a case its when 8O
Post Posted: Wed Oct 15, 2008 1:15 am
i have 6.5s in my zuk with flatbar welded to my standard arms to stop twist.I am still using standard rubber mounts,but have 3 spare ones in the car that i made out of polyurethane.i watched a mate split his case so i got a roctoy ring and welded it to my existing arms,with a few extra little pieces.dont know how much it helped,but so far so good. I only run 31s and a cig rear locker,guess it depends on how you drive
Users browsing this forum: Google [Bot] and 232 guests
