It is currently Mon Oct 12, 2026 2:12 am
Post Posted: Sat Jul 09, 2011 4:20 am
:helloo: Guys,
I'm am half way into fitting my winch, went to put the fairlead, and it won't go on. There is not enough room between the inside of the bar and the winch to get the nut in there to bolt the fairlead on as shown on this picture here.
Second issue is shown on this picture here
I can't do the bold up cus the fair lead is in the way, i would move it up by re-drilling the holes, but then there would be no way of bolting it on once again cus if the first issue :(
SO what do i need to put the fairlead on?
A off-set fairlead? or am i doing something wrong? :?
Cheers,
Andy
Post Posted: Sat Jul 09, 2011 4:23 am
Issue 1.
Can the fiarlead nut go in before the winch? Or there there no physical room in any way?
Issue 2.
Grind off the some of the fairlead.
Post Posted: Sat Jul 09, 2011 4:27 am
SierraDan wrote:
Issue 1.
Issue 2.
I have been told not to grind the fairlead down by the guy at me local 4wd shop.
And no there is not physical room to put the nut on, with out the bolt going in on a angle.
Post Posted: Sat Jul 09, 2011 4:32 am
buy an ARB bar?
2.
was it smiffkid at your local 4wd shop?
can you grind down the fairlead nut so it's "low profile"
the fair lead should be in line with the bottom of the drum so the rope comes straight out.
Vehicle: Work van
Post Posted: Sat Jul 09, 2011 4:34 am
Point the fairlead bolt outwards so you only have the head near the winch, as for grinding the fairlead I would ask dank rather than your local guy
Swb softie spoa cromo front -50 beadlocks 6.5s :D
Post Posted: Sat Jul 09, 2011 4:36 am
Just had a look in google, and this picture come up, is that a off set failead? Cus that would solve my issue :?
Post Posted: Sat Jul 09, 2011 4:38 am
Instead of using bolts get some allen key cap screws.
Post Posted: Sat Jul 09, 2011 4:41 am
The bolt at the bottom of the pics, can that be used to attach the fairlead?
Post Posted: Sat Jul 09, 2011 4:42 am
cant you just rotate it 180 degrees and use that bolt?
Vehicle: Suzuki Jimny 2010
Post Posted: Sat Jul 09, 2011 6:40 am
x2... Looks possible from the pic anywyas, and it looks like that's the way it is in the other "offset" picture?
Post Posted: Sat Jul 09, 2011 7:03 am
i think you'll find that the fairlead is symmetrical.
Post Posted: Sat Jul 09, 2011 7:09 am
Agreed, just called it offset so he knew which pic lol
Post Posted: Sat Jul 09, 2011 7:11 am
so rotating his fairlead 180* isn't going to change a thing. :wink:
Post Posted: Sat Jul 09, 2011 7:16 am
Ahhh I get what you mean now lol my bad... Sat night man brains switched off haha
Post Posted: Sat Jul 09, 2011 7:33 am
Looks like your hoarse fairlead is upside down , the bolts that hold the winch generally have the same centres as the winch mounts , a better picture would help from the front , Cheers Paul.
Post Posted: Sat Jul 09, 2011 8:56 am
I can't really see how much the bolt is touching the fairlead in pic 2, but why can't that bolt be done up with a spanner?
Vehicle: WR250F/Jeep XJ
Post Posted: Sat Jul 09, 2011 9:20 am
Couple of options:
Option 1: Space the winch back with some washers to fit the bolt head. Been done plenty of times and is effective
Option 2: Bolt the fairlead to the bottom mounting point of the winch and cut the bar plate out of the way so it only rubs on the fairlead if its in the way. This is how mine was on my ARB bar.
Option 3: Use an offset hawse fairlead.
Monkey if you want to, you can keep your fairlead and I will do you an offset one for 50% off which is $85 -50% + $10 postage = $52.50.
LIKE US ON FACEBOOK - KPD4x4
Post Posted: Sat Jul 09, 2011 9:42 am
dank wrote:
Couple of options:
:D I will do that! Thanks heaps Dan.
And thanks for your help every one, much appreciated. :D
Cheers,
Andy.
Post Posted: Sat Jul 09, 2011 10:48 am
No probs mate thats what we're here for!
Post Posted: Wed Jul 27, 2011 10:53 am
Off-set fair lead works much better! :D
Thanks again Dan! 8)
Post Posted: Wed Jul 27, 2011 11:03 am
u can grind your fair lead, but having the offset 1 works well, so no need to
dodgy brothers mechanical
Post Posted: Wed Jul 27, 2011 11:10 am
does it get hot much with hwy driving?
Post Posted: Wed Jul 27, 2011 11:13 am
Joe: No! Not all, even on the beach the temp gauge didn't even move a bit. :)
Post Posted: Wed Jul 27, 2011 11:17 am
it looks tuff, just thought she may lack a bit of air intake.
Post Posted: Wed Jul 27, 2011 11:22 am
i was thinking the same thing with the lights & winch controller there + the stock bumper has a couple of decent air dams in it that are now gone.
Vehicle: 4wd
Post Posted: Wed Jul 27, 2011 11:26 am
What size winch monkey?
Watch out or you'll get sued.
Post Posted: Wed Jul 27, 2011 11:31 am
9000lb :P
Vehicle: 4wd
Post Posted: Wed Jul 27, 2011 11:33 am
You running dual battery?
Post Posted: Wed Jul 27, 2011 11:34 am
no! Got no room :cry:
Users browsing this forum: Google [Bot] and 243 guests
