It is currently Sun Oct 04, 2026 6:24 pm
Post Posted: Tue Jul 12, 2011 8:30 pm
Hi All,
My indicators randomly stop working, when im at the lights turning left or right and have my indicator on it randomly stops then about 10 mins later they start working again. Anyone got any ideas, its a 91 SWB vitara.
Thanks
Post Posted: Tue Jul 12, 2011 9:35 pm
1.Bad connections internally in the indicator switches,
Strip em down use some contact cleaner
2. Power loss to indicator relay
Check power to relay, loose wire ect
Try hazards when indicators don't work
If hazards work, u will have power to flasher relay.
Problem will be in indicator switches, repeat steps 1
Sik as drover, 32" mongrels, 4age 20v, 2" sus, 2"
Post Posted: Tue Jul 12, 2011 10:22 pm
Not correct on teh hazard power, when it stops working, try the hazards, if it starts to work it the indicator power supply, maybe a loose fuse, if it still doesnt work its the flasher unit, behind the drivers side speaker
I am going with Flasher unit
Post Posted: Tue Jul 12, 2011 11:35 pm
When I think about it, ur right ,, my bad
Post Posted: Tue Jul 12, 2011 11:38 pm
Thanks guys will try tonight, when indicators stop working the the hazards stop too, fuse is in properly
Post Posted: Wed Jul 13, 2011 12:41 am
indicators are over rated.
stick right arm out when turning right, bend at elbow and point hand up when stopping or turning left.
if window is up, wind down-or even better-remove windows (they just get in the way)
watch out for motorbikes lane splitting (helmets hurt)
works for me!
Post Posted: Wed Jul 13, 2011 1:32 am
Lol nice
Vehicle: SJ80, SE416
Post Posted: Thu Jul 14, 2011 5:31 am
No-one yet has mentioned the hazard signal switch as a possible cause of the problem...
Just another possibility as it has both normally closed and normally open contacts that will stop indicators working if the switch is stuck half-way down.
Vehicle: LWB Sierra & XL7
Post Posted: Thu Jul 14, 2011 9:00 am
And when someone honks at you, Stick your arm out the window, bend at the elbow and extend middle finger.
Post Posted: Thu Jul 14, 2011 9:43 am
just had a look at all the wiring and the fuses, all are fine. tomorrow ill get another flasher unit and ill let you all know how i go.
Users browsing this forum: Google [Bot] and 159 guests
