| Author |
Message |
dockers
 Posted: Thu Oct 16, 2008 5:46 pm |
whos done this? was it hard? was it worth it?
steve
Joined: Sun Jun 11, 2006 11:30 pm Posts: 7681 Location: Brisbane
Vehicle: 75 Cruiser
 Posted: Thu Oct 16, 2008 6:02 pm |
lots of people do it.
easy if you're in to that kind of stuff.
worth it? I don't think i'd bother, if someone gave you the WT diffs already converted it might be ok, but for the extra width... i don't think it makes that much difference to anything, maybe just a cool factor?
rustylj
Joined: Mon Oct 13, 2008 10:30 pm Posts: 4 Location: brisbane
 Posted: Fri Oct 17, 2008 3:07 am |
thats bullshit. they make a sierra flex much better in the bush
steve
Vehicle: 75 Cruiser
 Posted: Fri Oct 17, 2008 10:22 am |
How much work did you put in to yours and how much improvement did you get? Post up some measurements and photos.
zookernator
Joined: Sun Mar 16, 2008 10:30 pm Posts: 813 Location: Tasmania
 Posted: Fri Oct 17, 2008 10:15 pm |
go out all, get hilux diffs!!!!!!!!!!!!!! Plenty of benefits!! Not a good pic, but their the same tire (32X10.5), but different rims (obviously).
I realise there would be heaps more work involved, but you get heaps better results! Inc Flex
This is zook front, lux rear
_________________ F&R ARB air lockers, lux diffs, 4 link coil rear,
steve
Vehicle: 75 Cruiser
 Posted: Fri Oct 17, 2008 10:16 pm |
i tend to agree zookinatorious. That's what my original point was, i know people thinks that's "bullshit", but the question is, if it's actually worth it... and i don't think it is. It'd be about as usefull as extractors or twinsticks (heh here we go). sure you might get some gain, but are we talking about 5%? why bother? If you're going to swap diffs why not put bigger diffs under there while you're at it, to increase strength aswell. toyota, nissan, which ever. get some diffs with the same offsets as sierras. I'd probably go spring under with some lift, so it all would look pretty stock standard.
PS. Nothing wrong with a NT sierra, it'll go as far up a track as a NT with WT diffs. You can always get width with bigger offset rims if you want an easy option.
zookernator
 Posted: Fri Oct 17, 2008 10:26 pm |
Zook_Fan
Joined: Thu Mar 13, 2008 10:30 pm Posts: 4531 Location: Toowoomba
 Posted: Fri Oct 17, 2008 10:49 pm |
you got any pics of the inboarded shocky set up u run?
zookernator
 Posted: Fri Oct 17, 2008 10:58 pm |
Replaced the original bar thingy with a bit of 50X50 RHS, with 2 bolts welded through it!! Their 8" apart. And yup, i know that bush looks yucky, all fixed up now though!! haha
Zook_Fan
 Posted: Fri Oct 17, 2008 11:07 pm |
so you welded onto chassis? or cut of the old and welded onto what was left?
steve
Vehicle: 75 Cruiser
 Posted: Fri Oct 17, 2008 11:30 pm |
that's not the standard cross member of a chassis anyways.
zookernator
 Posted: Sat Oct 18, 2008 1:57 am |
Zook_Fan wrote: so you welded onto chassis? or cut of the old and welded onto what was left?
Left thye original mounting brackets (as seen in the pic), welded back onto them.. and a small weld onto the chassis, where the original one was. Pretty much re-welded where the original weld was..
dockers
 Posted: Sun Oct 19, 2008 9:38 pm |
whats the difference in width between wt and nt.
Taff
Joined: Sun Aug 13, 2006 11:30 pm Posts: 889 Location: Brisbane
 Posted: Mon Oct 20, 2008 12:37 am |
around 80mm.
didnt you get defected for your lux diffs zookenator?
zookernator
 Posted: Mon Oct 20, 2008 10:45 pm |
Well, not really for the diffs themself no. Got done for being to high and to wide compared to a stock zook. This is only cause we cant get things engineered down here
Taff
 Posted: Tue Oct 21, 2008 2:28 am |
