It is currently Tue Oct 06, 2026 7:22 pm
Post Posted: Fri Jul 22, 2011 7:21 am
for a few months now my brake peddle has pulsed when stopping.
wheel bearings appear fine with little to no movement and the calipers and
backing plates appear to have no movement
any ideas? appears worse after driving fastish but that may just be cos i am going faster. :roll:
i think it started after i replaced the rear diff center and axle seals but i cant be sure that that is when it did start.
Post Posted: Fri Jul 22, 2011 7:23 am
Hot spot on the discs?
Post Posted: Fri Jul 22, 2011 7:24 am
foot massages?
id say warped rotors, mine are doing that now
Post Posted: Fri Jul 22, 2011 7:26 am
i wouldn't have thought so as i haven't been over 40kph for at least 12months. 8O
Post Posted: Fri Jul 22, 2011 7:29 am
one of your drums isn't on totally square
Vehicle: LJ80
Post Posted: Fri Jul 22, 2011 7:32 am
last time i had this problem i fixed it with new pads
they were not wearing square.
if yours are not wearing well i would suggest filing/sanding on concrete ect
Post Posted: Fri Jul 22, 2011 7:33 am
belt with hammer? or just rattle gun the 4 nuts as tight as they go?
Post Posted: Fri Jul 22, 2011 7:38 am
Hey Shep, have ya had ur wheels off lately? I'm thinkin like Royce said. Check ur discs and drums and wire brush their mounting faces.
Post Posted: Fri Jul 22, 2011 8:02 am
might work, otherwise pull the drums off, give the mating faces a clean and stick em back on, only needs a little bit of shit on there
Post Posted: Fri Jul 22, 2011 9:31 am
i had a dt175 motorbike that did this with the front drum brake. could feel the lever going in and out. lol dunno what it was but
Post Posted: Fri Jul 22, 2011 9:32 pm
Hot spots can also occur when you drive into water and put your foot on the brakes when they are hot.
255 characters
Post Posted: Sat Jul 23, 2011 11:05 pm
So you fixed this yet Shep? :-)
Post Posted: Sat Jul 23, 2011 11:34 pm
i reckon royce is on the money. have cleaned up one side and it is a little better
however the four studs are quite loose in there holes so i dont think it will ever be
properly fixed. the car just needs to hold together for about 1000km and then i
can fix everything properly.
Post Posted: Sun Jul 24, 2011 5:28 am
I found on mine sometimes pulling the drum off and rotating it 90 degrees and back on would fix it
Users browsing this forum: No registered users and 235 guests
