It is currently Sat Oct 31, 2026 6:01 pm
Post new topic Reply to topic  [ 117 posts ]  Go to page Previous  1, 2, 3, 4  Next
Post Posted: Wed Oct 01, 2008 1:54 am
I know that, I hate christmas trees too but the old budget ain't that flexy at the moment
Post Posted: Tue Oct 21, 2008 10:37 pm
OK seeing I am a nice guy I took some time out of my hektik schedule to have a look :)
the kit, gun, 4, 5 and 6mm noses and some inserts in a metal box $231.98 +gst
the gun alone $89.62
3, 4, 5 and 6mm noses are all $29.30 +gst each
there is an 8mm nose but its been discontinued and I just bought our last one :wink: I think 8mm is a bit above what you would use a nutsert for anways
all inserts are between 15 abd 20 cents each + GST
add postage onto that, 3kg express post bag would cover it easilly
Where is that through?
Post Posted: Tue Oct 21, 2008 11:17 pm
my work, I'm on the northside but could probably sort it out to be collected from Wacol way as well, or I can jsut post em to you
Post Posted: Wed Oct 22, 2008 12:36 am
Hey Royce, what size hole is required for the 6mm nutsert
Post Posted: Wed Oct 22, 2008 12:41 am
3/8"
Post Posted: Wed Oct 22, 2008 12:43 am
3/8"
I use 9.5mm :P
Post Posted: Wed Oct 22, 2008 12:53 am
your 0.03 t0 0.1mm too small then :P
Post Posted: Wed Oct 22, 2008 1:12 am
I just egg it out with an easy-out :lol:
Post Posted: Wed Oct 22, 2008 1:56 am
So a metric insert needs an imperial hole :? :?
Post Posted: Wed Oct 22, 2008 9:26 am
i have found different brands need different size holes... our m6 range from 8-9.5 mm
Web wheeler extroadinaire
Post Posted: Wed Feb 03, 2010 3:26 pm
im in mel where can i get one?
and why had i not herd of one of these before?
company car's make the best 4x4's
Post Posted: Wed Feb 03, 2010 10:35 pm
Yeh they are a brilliant device. Use em to install rock guards n shit at work. Used em for my snorkel, etc...
Post Posted: Thu Feb 04, 2010 1:31 am
www.justtools.com.au
Vehicle: jimny
Post Posted: Thu Feb 04, 2010 3:23 am
i sell em at Wurth as well, like all german stuff we are definately not cheap though, pm me of you want to buy any quality tools
Vehicle: MY2019 Jimny
Post Posted: Thu Feb 04, 2010 3:48 am
Allen drivers? I need a set soon...
Vehicle: jimny
Post Posted: Fri Feb 05, 2010 2:00 am
do you just want a set of 1/4 inch hex key heads or the socket type?
anyway here is link for most of our tools, however we do have over 10000 part numbers so the tools are all through the whole catalogue in their sprecific sections, panel beating, mechanical etc. this link is just the straight out tool section
http://www.wurth.com.au/autocat12.asp
Post Posted: Fri Feb 05, 2010 2:04 am
Allen wrenches, t bar style, in metric.
Post Posted: Fri Feb 05, 2010 10:57 am
dont try and use stainless bolts in those nutserts cause you be cursing and ready to break stuff we use them in or caravans with stainless bolts even with lube on them they bind up and are a bitch to get out cause the nutsert decides to spin on you. other than that they are not to bad
Post Posted: Fri Feb 05, 2010 4:33 pm
Excuse my ignorance, but I have never seen a nutsert, the tool or how they work, but after reading the thread it sounds like i have to have one....mmmmmm tooooollllllls but more so to get rid of all the plastic pop screws in my car. Anyway, can anyone post up some pics of the tool, mandrels, noses etc and maybe even in opperation as well.
The pics at the start of the thread dont explain it clear enough as I dont really know what I'm looking at. Cheers.
If your not breaking shit, try harder!!!
Post Posted: Fri Feb 05, 2010 5:04 pm
found this
http://www.justtools.com.au/prod3826.htm
Post Posted: Fri Feb 05, 2010 5:24 pm
Thanks for that....so what to the mandrels look like and whow do they opperate? are they removeable?
Post Posted: Fri Feb 05, 2010 5:44 pm
Come and have a look at my snorkel mate. It's held on by them
Post Posted: Fri Feb 05, 2010 6:04 pm
Ok, will do
Post Posted: Mon Feb 08, 2010 2:41 am
nutserts are basically pop rivets without a pull stub on it rather the threaded mandrel is and when you squeeze it it forms a bulge at the back stoping it pulling through.
pretty handy but dont buy the stainless nutserts or use stainless bolts in them like everyone else said
Post Posted: Mon Feb 08, 2010 3:33 am
Thanks for that, Yeah....I went over to Rusho's and had a look at one holing his snorkel on....bloody brillant! Cant believe I haven't seen this before, it's on the to buy list thats for sure.
Post Posted: Wed Feb 10, 2010 3:42 am
For those that haven't seen one before I took some pics of mine.
Nutsert tool, it works very similar to a pop rivet tool
M6 and M4 mandrels
M6 mandrel
This is how it works. Screw the inner part of the mandrel into the tool
Now slide the collar over the inner part and screw it into the tool's housing
Take your nutsert and screw it onto the inner part
Now push the nutsert into the appropriate sized hole and squeeze the handles together
Post Posted: Wed Feb 10, 2010 3:50 am
Ah nutsert! Always heard of then as riv-nuts! Pretty flash tool!!! Mines an old battery hook, a spacer, washer and another nut of the same thread as he batt hook/riv nut. Bush mechanics FNQ style :P
Post Posted: Wed Feb 10, 2010 3:53 am
Yeah different name, same thing.
I have pulled a few nuserts without the tool. It's a lot quicker/easier WITH the tool!!!
Post Posted: Wed Feb 10, 2010 5:26 am
Thanks DAMO, thats exactly what I was looking for.
I had a look at some on Rusho's Coily...Bloody awsome.
And generally better success rate too, nothing worse then a loose nutsert
Users browsing this forum: No registered users and 18 guests
