It is currently Sun Nov 01, 2026 10:14 pm
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2
Post Posted: Wed Jul 27, 2011 12:52 pm
Also wanted to know, with using this ratio, will the initial and top end speed increase ?
Post Posted: Wed Jul 27, 2011 1:06 pm
No. The opposite.
You currently have 3.7:1 diff ratios according to your previous posts. Fitting 5.12:1 gears will reduce your top speed, but give you better acceleration. If you are, or already have fitted larger tyres, the 5:12 gears will help bring you gearing closer to the way it was before the larger tyres.
Post Posted: Thu Jul 28, 2011 9:20 am
No. The opposite.
That's even what i thought. What crown wheel and pinion should i use to increase the top end and the acceleration of the car ?I am going to fit a 1.6 16v suzuki esteem engine in the car and want it to move faster..
Post Posted: Thu Jul 28, 2011 12:26 pm
You don't get both from diff gears. 5.12 will give you the best acceleration, 3.7 will give you the best top end but it will be slow getting there.
Post Posted: Thu Jul 28, 2011 12:33 pm
Sparks wrote:
No. The opposite.
3.7 ( what you currently have ) is as tall as suzuki ratios get. You should be able to get well past 150kph with 3.7's and G16B, and sierras are not built to go that fast :(
Post Posted: Thu Jul 28, 2011 5:03 pm
Friends of mine get a top speed of about 175Kmph, on their sierra's with the 1.3 engine's with a high lift pipercross cam and a good intake and headers. I want something faster than that! Some one told me to put the vitara 1.6 crown and pinion in the stock differentials to achieve higher speeds. I might have made a mistake with the ratio he told me...
Post Posted: Thu Jul 28, 2011 9:15 pm
You Sir, are an idiot... 8O :roll: 8O
Users browsing this forum: No registered users and 10 guests
