It is currently Tue Oct 20, 2026 2:13 am
Post Posted: Fri Jul 29, 2011 12:34 pm
Hi Guys,
I have a Rough Country steering Damper.
WIll i notice any difference is i replace it with a RTC tough dog damper?
Steering has some wobble and is a bit wandery at higher speed.
Car has been lifted and castor correction fitted.
Post Posted: Fri Jul 29, 2011 12:47 pm
Yes! But it will not fix the issue, just cover up the problem more, but they are great off-road....
Post Posted: Fri Jul 29, 2011 12:50 pm
A steering dampener will only mask the problem. Your better off spending the money resolving the issue of the wobble
- wheel balance
- buckled wheel
- wheel bearings
- kingpin bearings
- suspension bushes
- steering box
Member of C.O.R 4x4
Post Posted: Fri Jul 29, 2011 3:04 pm
I got Water in my tyres that i cant get out it is causin some wobbles.
Post Posted: Fri Jul 29, 2011 6:59 pm
Crikey, an there are no tyre dealers in WA who can take the tyre off and drain the water, making your car safe, bugger.
Post Posted: Fri Jul 29, 2011 7:00 pm
Post Posted: Fri Jul 29, 2011 9:43 pm
- wheel balance
- buckled wheel
- wheel bearings
- kingpin bearings
- suspension bushes
- steering box
These are all relevant things to check when chasing a steering wobble, but one thing I don't hear people mention much is the knuckle scraper seals. In my own experience I have found that having freshly rebuilt knuckle assemblies makes a lot of difference.
If you check all your bearings, bushes rod ends etc and are still getting the wobble do a knuckle rebuild.
Users browsing this forum: Google Adsense [Bot] and 258 guests
