It is currently Tue Oct 27, 2026 1:01 pm
Post Posted: Sat Jul 30, 2011 9:00 pm
hey guys when i got the zook about 2 years ago the previous owner had stacked the front of it into a stump and bent in the tube cross member on the chassis. anyway what i was wondering was can i fix it? because i cant fit an after market front bar without modding the mounts on it. this is because the chassis rails have been pulled in at the same time which makes things very very gay x4.
if anyone has any suggestions on what i could do they would be muchly appreciated thanks.
Aaron
Post Posted: Sat Jul 30, 2011 9:11 pm
Cut it out and replace it. Push the rails out while your at it and weld back in a bit of tube to the correct length once rails are where you want them.
Post Posted: Sat Jul 30, 2011 9:59 pm
cut it out and replace it. And while your doing it put i stronger pipe through the middle.
I had to replace mine after a recovered using the factory tie down.
Post Posted: Sun Jul 31, 2011 8:08 am
hey guys i was thinking half drunk and what would i have to do to replace it i thought if i cut it out the front of the car would collapse in?
Sierra, 32's, Airlocked, 6.5'd, hopefully ruf soon
Post Posted: Sun Jul 31, 2011 8:40 am
Drunk typing :lol: There is entry of other goodness to hold your car together :P
Post Posted: Sun Jul 31, 2011 8:51 am
Simple. Cut a piece of box section steel to the same length as the distance between your rails. Bash it in behind the cross member and tack weld in place. Think about where you place your tack welds, as you will need to be able to get a grinder to them later to break out the brace.
After your temp chassis member is in place, cut out the old cross member and repair. If you want more specific infor about how to go about this, PM me.
Post Posted: Sun Jul 31, 2011 8:55 am
x2
Post Posted: Sun Jul 31, 2011 8:56 am
Not a bad time to do RUF though...
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Sun Jul 31, 2011 8:24 pm
Like this:
The far side did get plug welded too after lining up the steering box, but before the extra plate went in with the crush tubes.
and while your at it,
Power steering!
This way is engineerable.
Some engineers need fish plates on the top and bottom of the chassis too though, you couldnt really tell easily with mine when finished that it was extended.
Post Posted: Mon Aug 01, 2011 7:09 am
hmm yeah i would try to do this i would do a ruf but i would fuck it up somehow one day ill go and buy some steel to fix it ill get a pic of the actual cross member later on
Post Posted: Mon Aug 01, 2011 7:11 am
If you think you'll stuff up a RUF then you're not ready to repair the stock crossmember. It's fabrication work, involves critical welding of the chassis, and plenty of alignment and measurement either way.
Post Posted: Mon Aug 01, 2011 7:17 am
You have made a excellent point (thanks for making me look stupid :lol: ) I want to get it fixed so i can get a new front bar (my arb bull bar is shitty i recon) I like the look of the jml one but i cant get one because none of the mounts line up with the chassis rails :cry: .
If i was to get someone to do it profesionally it would cost me more arms and legs than i have soo its gay x7.
Post Posted: Mon Aug 01, 2011 7:33 am
i had the same problem well still do haha i just cut the tube out and got my current Custom bumper to hold front end together it works but il make it strong when i put the winch on front end
Users browsing this forum: No registered users and 274 guests
