It is currently Wed Nov 04, 2026 2:31 pm
Post Posted: Mon Aug 01, 2011 11:29 am
There was some buzz about the altered ego 4.5" lift on here a little while ago.
Here is an install thread from Pirate:
http://www.pirate4x4.com/forum/showthread.php?t=993529
A) there looks to be some dodgy build quality here, maybe even dodgier than "what's a metric drill" calmini.
B) this isn't ever going to be engineerable in any state of Australia. Way too much whaky geometry and weird workarounds. Anyone want to guess what's going on with caster and steering axis inclination once it's installed?
Anyway, nice to see it in the flesh and not in poser ramp shots.
Post Posted: Mon Aug 01, 2011 11:35 am
should have grimbo'd that Gwagon. :lol: :thefinger:
http://auszookers.com/index.php?name=Fo ... ltered+ego
Post Posted: Mon Aug 01, 2011 11:44 am
Sure - there's the buzz, which mostly seemed totally non-critical hyperbole (except for some comments by Fatzook). To me, It looks like a cheaply made and questionably engineered solution, and that install thread is the proof.
Post Posted: Mon Aug 01, 2011 12:04 pm
Yeah that front end is damn ugly in its arrangement
Post Posted: Mon Aug 01, 2011 2:38 pm
I'm bloody glad I went with the tried and tested Calmini kit!
Should be here tomorrow!
Post Posted: Mon Aug 01, 2011 8:15 pm
How much did you pay for shipping? I tried to order but website wanted $1000+ for shipping.
Neither companies will email me back
Post Posted: Mon Aug 01, 2011 8:48 pm
Order off low range mate, I ordered from low range, and they charged me about $300 for shipping. Ask him if he can separate it into two receipts though. I learnt the hard way and once it hit our shores I had to pay around $400 in tax. :(
Calmini kits been awesome so far :)
Matty
Post Posted: Mon Aug 01, 2011 9:04 pm
im not a fan of having a spacer in your front suspention. mounting the strut. Might hamper the chances of getting these kits road regal.
Post Posted: Mon Aug 01, 2011 9:41 pm
Shipping was $450 DHL Express. I also got a mini spool.
Regards the email, make sure you check your junk folder, sometimes I've found their email going straight there? If you still have no luck like I did just give them a call.
Post Posted: Tue Aug 02, 2011 12:13 am
I'm pretty certain that most engeneers would vomit in their mouths at the site of a spaced strut :?
Vehicle: lj81 stockman
Post Posted: Tue Aug 02, 2011 12:40 am
got to love the home made camber kit
the wobble rocks
Post Posted: Tue Aug 02, 2011 12:45 am
The Calmini kit has a spaced strut & that has been engineered. :wink:
Post Posted: Tue Aug 02, 2011 12:48 am
so it has a 50mm alloy block sandwiched btween the strut and the knuckle assembly? :?
Post Posted: Tue Aug 02, 2011 12:51 am
RCA's in vic have been engineered in the past. Offset ones have been knocked back.
Post Posted: Tue Aug 02, 2011 12:58 am
Are you seeing the freakin dodgey block at the connection at the knuckle and the strut? i have no issue with the spacers at the top of the strut. if your struts is going to blow the rubber boot at the top, its going to blow with or without the spacer.
Post Posted: Tue Aug 02, 2011 12:59 am
no but it does have a spaced strut just like the calmini kit. :wink:
having seen the abortion of a Vitara that Athol engineered, I'm pretty sure that he'd pass the Altered Ego kit.
Post Posted: Tue Aug 02, 2011 1:08 am
How much was duty tax?
Apart from ride height, what is the chance ill get defected for the calmini kit in QLD?
Post Posted: Tue Aug 02, 2011 1:27 am
IMO it's about the same level of dodgyness as the rear ball joint spacers that people run in the rear of vitara's...
Users browsing this forum: Google [Bot] and 90 guests
