It is currently Fri Nov 13, 2026 3:01 pm
Post Posted: Mon Aug 01, 2011 9:11 am
hey all,
on a US site a set of 5.38, 5.62 diff gears for a vitara (trackick as they call them) have come up, $500 for the 5.38 and 1 grand for the 5.62's. i would like to run 31's but my issue is gearing, would the 5.38's give me some kind of decent gearing (stock?).
im not really prepared to pay $1000 for the 5.62's, before last week i never had heard of these.
so has anyone heard anything about these and would it be worth the money or just stick with my current 5.12?
cheers
Mitch
Vehicle: 1995 SWB Sierra TinTop
Post Posted: Mon Aug 01, 2011 9:13 am
thats low bro haha
95 Sierra SJ70 TinTop
Post Posted: Mon Aug 01, 2011 9:19 am
Post a link to the site, pretty sure they don't make them anymore and when they did they were pretty weak :?
Post Posted: Mon Aug 01, 2011 9:22 am
http://www.puresuzuki.com/Ring%20&%20Pinion.htm
these WERE 5.83s for 330 per end, but discontinued..
are you auto or manual?
Post Posted: Mon Aug 01, 2011 9:23 am
he;s manual
Post Posted: Mon Aug 01, 2011 9:24 am
Be good if it gave good gearing. But would they make highrange terrible? (Gearing isnt my forte')
How would this be with highway
Post Posted: Mon Aug 01, 2011 9:25 am
I would stick with the 5:12's and look for better gearing in the case.
5:12's are pretty damned low, but 5:38 is not much of a jump at all for a grand. Even the 5:62 is not a whole lot lower especially for the money.
Most guys use those close ratios to fine tune their upper RPM for power, and to keep the rev low. Now 5:88's may be a bigger difference, and they can be had for around $200 fo a set of ring and pinions
Post Posted: Mon Aug 01, 2011 9:31 am
To get you high range gearing back with the 31's you'd need to look at the 5.6's.
That's a lot of coin just for R&P's even in my eye's, as once you get them here you still need to get them installed, unless they're complete diff centres?
Post Posted: Mon Aug 01, 2011 10:15 am
thanks for the reply, its $500 for the 5.38 but yeah i get what ur saying.
skyman; where can you can those 5.88's from??
atari: thats what the seller said but wasnt sure. and yeah they are in "thirds" as they call them. the front has 22 spline so i would get just the R&P but the rear is 26 spline so would prob get the centre if shipping didnt cost to much. but if its not worth it, then im not going to waste my $$$.
especially when i just got my front diff swapped to the steel housing.
this is the link: http://www.zukikrawlers.com/showthread.php?t=39475
dont buy them all incase i need them!
Mitch
Post Posted: Mon Aug 01, 2011 10:21 am
the words "hard to find " would put me off.
A lot of work/money, with little chance of finding another if breakage happens.
I want 5:6's but don't want rare, I want piles of easy to get spare bits.
Post Posted: Mon Aug 01, 2011 10:22 am
Yes where are the 5.88's from ?
Post Posted: Mon Aug 01, 2011 10:27 am
An undertaker could be a better/cheaper option ?
Post Posted: Mon Aug 01, 2011 1:01 pm
well undertaker requires a lot of custom fab works new hole in tunnel, new front & rear shafts ect.
this is what i asked about the rarity of the gears,
ok ill see what i can find, do the 5.38-5.62 gears come up for sale often? when paying decent money for them i dont want damage them, then not be able to find a replacement set if needed.
I have a couple of sets of each ratio. So if you need a replacement, I will probably have some.
ok well if the 5.6's are still going to be to low, then i guess im not going 5.3's. thanks
Post Posted: Mon Aug 01, 2011 1:54 pm
http://www.lowrangeoffroad.com/index.ph ... gears.html
Here's 5:38's for $213 an end
http://4wheelonline.com/categories.aspx ... ryid=38926
Post Posted: Mon Aug 01, 2011 9:28 pm
I am running 5.85 in an 8 valve 2dr with 31 simex centerpedes. I usually sit on about 90kmh on the highway in 5th. Off road they are really good.
Post Posted: Tue Aug 02, 2011 12:14 am
skyman wrote:
http://www.lowrangeoffroad.com/index.php/suzuki/samurai/differentials/4-57-and-5-38-ring-and-pinion-gears.html
Sky can you find any to suit the rear diff of a trackick?
Post Posted: Tue Aug 02, 2011 9:13 am
Here's 5:38's for $213 an end:
Dyslexia rules!
Are these 5.38 or 5.83?
Post Posted: Tue Aug 02, 2011 9:37 am
they are for a sami (sierra) would these fit tho? these 10 or 12 bolt?
Post Posted: Tue Aug 02, 2011 9:58 am
sierra's run 2 Vitara fronts, the vit rear is a fair bit larger.
Post Posted: Tue Aug 02, 2011 10:03 am
yeah so the front would fit but not rear. i guess thats the reason for you post before.
Post Posted: Tue Aug 02, 2011 10:07 am
Possible if a matching ratio for rear, maybe yota or similar exists,
then could still be possible...for people cleverer than me
Users browsing this forum: No registered users and 87 guests
