It is currently Mon Oct 19, 2026 9:52 pm
Post Posted: Tue Aug 02, 2011 9:31 pm
Hi guys..I'm chasing a set of yj springs, lifted or stock. Anyone got any they wana get rid of or know where I can get sum used ones?
Vehicle: '96 LWB trayback
Post Posted: Tue Aug 02, 2011 9:44 pm
YJ jeeps were never released in Aus.
You can pay through the nose to buy aftermarket ones from ARB.
Or look towards F310 widetrack feroza, or ln106hilux springs as an alternative.
Post Posted: Wed Aug 03, 2011 12:09 am
CJ7 springs are a better option for a sierra if your putting them on one.
Post Posted: Wed Aug 03, 2011 12:32 am
Yeh plan on putting them under a Sierra.. Why are they better? More accessible or something?
swb sierra, bundera diffs, spoa on yj leaves, 35's
Post Posted: Wed Aug 03, 2011 12:39 am
The donor vehicle was available locally.
CJ front springs are identical width (50mm) to sierra springs. (Rears are 2.5" still).
They are a softer rate spring more suited to the light weight sierra.
Post Posted: Wed Aug 03, 2011 12:45 am
Mostly the width (50mm) is why i would suggest them.
Post Posted: Wed Aug 03, 2011 2:25 am
Do you know if the rears (2.5" wide) springs are the same length as the yj's?
Post Posted: Wed Aug 03, 2011 2:33 am
44" long with centred pin compared to the yj 45" centred.
Have you ever tried researching for yourself rather than being spoon fed?
Try it, you might find it satisfying.
Post Posted: Wed Aug 03, 2011 3:03 am
Ahhh..anotha wanker on the forum. Nice.
Post Posted: Wed Aug 03, 2011 3:27 am
If your after rears im pretty sure i have a pair.
i bought a set of 4 and only used fronts
Post Posted: Wed Aug 03, 2011 3:37 am
Just did sum reading.. As previously stated yj's are an inch longer & half an inch wider in the front compared to cj's, however cj rears are apparently the same length & width (2.5") as the yj's all round..only the fronts are different. Correct me if I'm wrong :-)
Sounds good mate, I'll send ya a pm.
Post Posted: Wed Aug 03, 2011 3:51 am
CJ fronts are 50mm wide.
Cj rears are 65mm wide.
Users browsing this forum: No registered users and 26 guests
