It is currently Sat Oct 10, 2026 5:30 am
Post Posted: Wed Aug 10, 2011 8:34 am
My suzuki sierra has a steering problem. The car when turning boths (lLeft or Right) wont return back to the Centre it either stays left or stays right. We have put a whole new steering system in the zook but we are still having the same problem. We are running the standard wheels at the moment with a 2 inch lift kit and new suspenstion. Would any of you have a clue what is wrong? and how to fix it? that would be good thanks :)
Post Posted: Wed Aug 10, 2011 8:38 am
were the swivel hubs been rebuilt at same time?
if so its likely the kingpin bearings are too tight
Post Posted: Wed Aug 10, 2011 8:41 am
yeh the were it might be the kingpins thnks mate i will have a look thanks heaps mate :)
Post Posted: Wed Aug 10, 2011 8:56 am
hey mate, A quick question. When we were going through the steering the front damper arm was burnt and very hard to move so we replaced it and we still have the same problem?
Post Posted: Wed Aug 10, 2011 9:10 am
there is a spec in kg for the kingpin setup.
its done with the felts and rubber not fitted to the rear of the swivel hub and you measure the tension by hooking a spring tension meter to the wheel stud from memory.
you could likely use a fish weighing scale.
someone on here will know the spec but 2kg rings a bell for me.
if you are missing the king pin shims its likely your problem
Post Posted: Wed Aug 10, 2011 9:13 am
Royce knows the correct weight.
Post Posted: Wed Aug 10, 2011 9:15 am
good because Ive never measured one yet :lol: :lol:
I just make sure they move freely but firmly
okay cheers boyz hope to see you on the track thanks heaps. peace
Users browsing this forum: No registered users and 264 guests
