It is currently Fri Nov 13, 2026 11:58 am
Post Posted: Thu Aug 11, 2011 6:34 am
I am looking to upgrade my tyres to 31/10.5/15 Maxxis Bighorns. Going to need to buy new rims at the same time so I want the offset to be right. Does anyone run a similer setup and can tell me what the minimum offset would be? I suppose I could just go for the largest offset i can get. Any suggestions?
Post Posted: Thu Aug 11, 2011 6:44 am
15x7 -13
Post Posted: Thu Aug 11, 2011 6:55 am
SierraDan wrote:
15x7 -13
x2..got some the other day, they are 8) 8)
Post Posted: Thu Aug 11, 2011 8:00 am
SierraDan wrote:
15x7 -13
x3
My Maruti build, Click WWW
Post Posted: Thu Aug 11, 2011 9:32 am
Im about to use 15x7 -13 also.
The only concern I have is will they fit under the WT flares with 31/10.5 and do they scrub on full lock at all???
Im the same as you, NT spacing with WT diffs and I will run WT flares or Duraflares.
I think the next size offset is -22 F100?? Sound right??
Post Posted: Thu Aug 11, 2011 9:41 am
Mine stick out about an inch past the flares :cry:
Post Posted: Thu Aug 11, 2011 10:00 am
i have wt diffs with nt spacing, 0 offset with 30 9.5 tyress and i have a good inchand a bit sticking outside wt flares
so id say they wont fit under wt flares
Post Posted: Thu Aug 11, 2011 10:28 am
I have 15x8 -23 with 31's and they stuck about about 2"
Post Posted: Thu Aug 11, 2011 10:17 pm
2inch past the flare or the body??
Post Posted: Thu Aug 11, 2011 11:00 pm
Flare I reacon :wink:
Post Posted: Sun Aug 14, 2011 2:29 am
Thanks for the replies. I'll go with the 15x7 -13.
Users browsing this forum: No registered users and 90 guests
