It is currently Fri Nov 13, 2026 12:56 pm
Post Posted: Wed Aug 10, 2011 3:31 am
I've just replaced my sierra carby and inlet manifold with one off a G16A vitara carby engine. I have three questions to those that have done this before:
1. Do you have to use the vitara accelerator cable or modify the sierra one? The cable I have is too long as the mounting for it on the vit carby is further over than on the sierra carb.
2. Where is this vacuum hose meant to hook up to. It comes out of the bottom of the passenger side of the carb, where three vac hoses come out together. It then loops around the front of the carb and over the thermostat housing.
3. Whats this hose for? I've blocked it off as there's nowhere on a sierra for it.
Member of C.O.R 4x4
Vehicle: SJ80, SE416
Post Posted: Wed Aug 10, 2011 3:38 am
Hose no.3 goes into the charcoal canister (mounted above the steering box in a Vitara instead of the firewall in a Sierra).
Not sure of the others without having a look at my vehicles.
Post Posted: Wed Aug 10, 2011 3:40 am
Ah thanks for that. I'll just leave it blocked then
Member of C.O.R 4x4
Post Posted: Fri Aug 12, 2011 6:12 am
bump
Surely someone has done this mod
Member of C.O.R 4x4
Post Posted: Fri Aug 12, 2011 7:05 am
The bottom picture looks the same as my valve cover breather...
Vehicle: Work van
Post Posted: Fri Aug 12, 2011 7:11 am
I have a g16a in my zook I will try and have a look for you tonight and report back :helloo:
Edit:I think number one runs to the airbox possibly? Will double check this
number 2 on mine is looped between two of the nipples where it comes off the carby, I will get some photos for you tomorrow
Swb softie spoa cromo front -50 beadlocks 6.5s :D
Post Posted: Fri Aug 12, 2011 8:09 am
Get efi
Post Posted: Mon Aug 15, 2011 2:30 am
Get efi
sell me a cheap efi engine Armsup
Member of C.O.R 4x4
Post Posted: Tue Aug 16, 2011 8:11 am
do you have more power after you put the vitara carby in
Post Posted: Tue Aug 16, 2011 10:51 am
Hi,
The small hose(one of the 3) goes to the canister, 1 to the vac advance, and 1 to the EGR.(yours is already in place)
The sierra Canaster only has 2 pipes on it, one to the tank vent and this one(purge line).
The large hose from the top of the carb(number 3) is the carb vent, but only when the engine is not running. The Small solenoid on top of the carb vents the float chamber to the throat during running, and this pipe when turned off..
Post Posted: Tue Aug 16, 2011 1:30 pm
zooker wrote:
Get efi
I need mine as spare, Since everything that turns into a big problem tends to happen with you. :mrgreen:
Overheat motor. check
Blow rear diff. check
:peaceout:
Post Posted: Sat Dec 10, 2011 11:20 pm
i have a question, what heater hose do i block off? there is 3 on the carby and only 2 in the sierra.
Users browsing this forum: Google [Bot] and 72 guests
