It is currently Fri Nov 06, 2026 1:27 am
Post Posted: Sun Aug 14, 2011 6:55 am
8O on. here's my dilemma..
I brought a set of 4" lifted springs and shocks
but my problem is they are so stiff that i have a good height lift but very little flex and an extremely stiff ride.
unfortunately I'm not very well educated in this area :blink: , but my thoughts were:
could i get 2" extended shackles and take the smallest leaf out of each spring?
also as a result of this would i get better flex, smoother ride and about the same height as i have now?
also what risks am i taking of bad steering or a spring snapping under the stress of one less leaf, considering that i will have extended shackles in to allow further movement??????????
please help :D
Post Posted: Sun Aug 14, 2011 7:05 am
well for starters it would help if we knew what kit it was that you bought and how many leafs are in each pack
Post Posted: Sun Aug 14, 2011 7:08 am
what brand springs?
personally I cant imagine how 4" lift springs could possibly work.
Vehicle: 2018 DMAX
Post Posted: Sun Aug 14, 2011 7:11 am
Got some pictures of these springs? cant see a 4" spring been very effective at anything, or very safe...
Post Posted: Sun Aug 14, 2011 8:05 am
Ok will get some pics up soon. I got the springs second hand though the car they came off only had them on for a year b4 he wreaked it.
I'm not home now but will check the brand again. To be honest I think I was fibbed to alittle. After installing them I think I gained a little over 2 inches but they are pretty stiff.
Vehicle: Sj70 tintop
Post Posted: Sun Aug 14, 2011 8:11 am
i assume a leafy sierra....
pop a leaf out, but they are always going to be a harsh ride.
Sj70 tintop
Post Posted: Sun Aug 14, 2011 8:21 am
take a photo of the leaf packs front and rear for us to see =) im betting if you take the pack out, remove the center bolt to release the springs and take the clamps off, you'll find theres only 1 leaf in there responsible for the stiffness (and lift). its usually the 2nd or 3rd leaf up in the pack.
Post Posted: Sun Aug 14, 2011 10:45 am
Could be the Trail Gear or Calmini 3 inch springs, the only ones I have seen in a 4 inch were some yank ones, Rough Country I think they were called. What tyre pressure are you running ?
Users browsing this forum: No registered users and 89 guests
