It is currently Fri Nov 13, 2026 12:51 pm
Post Posted: Sun Aug 14, 2011 10:10 am
Righto. I've just had my transfer case rebuilt with reduced ratio set at a local workshop dealing with Suzukis and it now sounds like all the gears are straight cut. Very noisy. The gears are 5.14 just purchased through Low Range Offroad. Are they normally very noisy or is this reason for concern?
It's not a Jeep!
Post Posted: Sun Aug 14, 2011 10:12 am
Nothing to worry about mate...normalish :wink:
Post Posted: Sun Aug 14, 2011 10:20 am
But only in low range. Should have no sound in high range.
Post Posted: Sun Aug 14, 2011 10:24 am
most likely a stupid thing to say but make sure they put oil in in before they gaveyou it back
I have a nice gear whine in high...more noticeable around 40+ km/h
Post Posted: Sun Aug 14, 2011 10:28 am
I have nothing. But I don't get Casper up that speed a lot these days on the speedo :wink:
Post Posted: Sun Aug 14, 2011 10:33 am
my 5.14s sound like my low range used to standard... low range sounds like a turbine under the body =P its a definite whine, but its not super loud.
Post Posted: Sun Aug 14, 2011 10:38 am
They will wear in and should quiet down after 1000kms. Change the oil at 1000kms too.
Post Posted: Sun Aug 14, 2011 10:53 am
A quick change of the subject. While Low Range are usually pretty good on price, TRAIL TOUGH are currently having a sale on Transfer Gearsets that are very well priced, even with the exchange rate coming off it's recent high.
Post Posted: Sun Aug 14, 2011 11:22 am
My gears (6.5:1 Rockhoppers) were a bit noisy when first installed. It took maybe 500km or a bit more and they quietened down. It's about this point I reckon you should change your gear oil.
Post Posted: Sun Aug 14, 2011 1:38 pm
The 5:xx cases should not be too noisy in high range after they are bedded in.
The 6:5's are notoriously bad, but the 5:xx gearsets are usually pretty quiet.
FWIW
FZ is right about the 1000Km oil change that; a definite need to do maintenance item.
Post Posted: Sun Aug 14, 2011 1:51 pm
mmm mines never quietened down... lol - its not gotten any louder though either... even with regular oil changes etc. i've been asked before driving on the highway (over the radio) if i was running a turbo or supercharger cos they could hear the gears whining! lol
Post Posted: Sun Aug 14, 2011 1:55 pm
Did ya do new bearing with the install, or just stuff 'em in?
sometimes the input bearign on the transmission sounds like a t-case. Course the input bearigns on the t-case whine when they get old too.
Post Posted: Sun Aug 14, 2011 1:58 pm
yeah was a full rebuild - got the calmini kit which had the whole lot in it, wasnt noisy before gears, got noiser after and stayed the same since... so long as its not getting worse its fine =)
Post Posted: Sun Aug 14, 2011 8:33 pm
What oil you running in there Alien?
Post Posted: Sun Aug 14, 2011 8:45 pm
Good old castrol 80-90 is the choice by most isn't it??
Post Posted: Sun Aug 14, 2011 10:19 pm
My 6.5's whine like fuck at 100+ km/h haha. Higher gears in low range sound like the apocalypse is coming :P
Post Posted: Sun Aug 14, 2011 10:35 pm
maybe we should all make an in-car video so we can compare noise... and also make a common noise in the car to compare that cos all cameras will be different... ie: turn on hazard lights to hear the clicking or something.
Post Posted: Sun Aug 14, 2011 10:39 pm
My 6.5's are the same. My dog won't even go in the car now, shit scared of the noise.
Post Posted: Mon Aug 15, 2011 2:47 am
skyman wrote:
High-way Star, what are your RPM's like at cruise speed?
About 3700rpm according to my speedo and tacho at 100km/h (around 60m/h for you Skyman). Gets to up around 4000rpm at 110km/h (~70m/h). The 3.7's were better at 110km/h as I think my G16 starts to come off its peak torque area at around 4000, plus its just starting to rev excessively for that motor. At 100 I still prefer the 3.9's though, mainly because there is almost never a need to change it back to 4th at that speed.
Edit what heppened to this thread? :?
Clearance Hole Technology :P
Post Posted: Mon Aug 15, 2011 8:28 pm
Everything is new. Even the cradle.
It's not a Jeep!
Post Posted: Mon Aug 15, 2011 8:32 pm
They gave it back empty. I installed it, filled it, then drove it.
It's not a Jeep!
Users browsing this forum: No registered users and 70 guests
