It is currently Fri Jul 31, 2026 7:44 am
Post new topic Reply to topic  [ 42 posts ]  Go to page 1, 2  Next
Vehicle: LPG 1.6 Sierra
Post Posted: Fri Aug 19, 2011 7:06 am
The car is hating these cold mornings, long gone are the days when it starts with first twist of the key.
I was a bit alarmed this morning - a freaking awful noise sounded like it was coming from the passenger footwell - I thought it was the speedo cable, but I was doing zero kph. BTW the noise disappeared 5 mins later when it was warm.
Does the speedo cable have an RPM cable inside also? I only saw the speedo winder part when I had it disconnected
Post Posted: Fri Aug 19, 2011 7:07 am
Care to describe the noise?
Car?
Post Posted: Fri Aug 19, 2011 7:12 am
Sounded like an arc'ing mig welder 8O but nowhere near as loud. Car is a 1990 Sierra running straight LPG. Noise was definitely coming from passenger footwell, not the engine bay or underside.
Post Posted: Fri Aug 19, 2011 7:15 am
cold mornings eh.... you didn't happen to have the heater fan on did you?
Post Posted: Fri Aug 19, 2011 7:16 am
If the car isn't moving then its either something in the engine bay, or the input side of the gearbox. If it was gearbox then it should stop when you put your foot on the clutch...
Theres no "rpm cable". The tacho works on pulses from the ignition coil.
I want my old sig back :(
Post Posted: Fri Aug 19, 2011 7:35 am
I'm baffled, just had a good poke around and nothing seems suspicious around where the noise was coming from and underneath too. I'm guessing it's cold weather related so i'll have to wait until my next 4am start to hear it again.
It's definitely coming from a more central position, not the engine bay. And was louder inside than out when I tried to pin point it this morning.
Stumped :?
Post Posted: Fri Aug 19, 2011 7:55 am
something in your heater fan, would be my bet
Post Posted: Fri Aug 19, 2011 8:17 am
x2
Post Posted: Fri Aug 19, 2011 8:35 am
yeah either something in the heater fan orrrrr has your oil cap come off the engine and been caught in the extractors and rattling around, then fell on the road? lol
i had mine do this, except the cap stayed in the pipes - luckily the plume of smoke coming out of the engine bay from oil landing on hot pipes made me pull over quick smart before it had a chance to fall onto the road.
but it made a bzzzzzt noise as it vibrated in the pipes =)
Post Posted: Fri Aug 19, 2011 11:02 am
starter ?
Vehicle: LJ20 LJ50
Post Posted: Fri Aug 19, 2011 11:26 am
Angry squirrel???
Camels have nice toes
Post Posted: Fri Aug 19, 2011 1:27 pm
MrRocky wrote:
starter ?
x2
79' LJ80 (sold) :(
95' & 97' sierra (sold)
Post Posted: Fri Aug 19, 2011 1:31 pm
TZAR wrote:
Angry squirrel???
x2
Post Posted: Fri Aug 19, 2011 2:34 pm
TZAR wrote:
Angry squirrel???
x2
Armsup
I put a slice of bread in the footwell, just incase :)
Post Posted: Fri Aug 19, 2011 8:39 pm
catalytic converter may have shat itself.
255 characters
Vehicle: 75 Cruiser
Post Posted: Fri Aug 19, 2011 8:47 pm
yeah, exhaust is under the passenger side.
Post Posted: Tue Aug 23, 2011 7:29 am
OK, thought it'd never catch it on camera, but I lucked out this morning (luck? :? ) The only thing i've done is flick the ignition to 'acc'
[flash width=480 height=385]http://www.youtube-nocookie.com/v/4cohmQMIYO8.swf[/flash]
Post Posted: Tue Aug 23, 2011 7:35 am
Heater fan
Vehicle: Sj70 tintop
exposed wire earthing out?
screaming banshee?
was the heater fan on?
thermo fan?
sounds like something simple and doesn't sound extremely serious.
Sj70 tintop
Post Posted: Tue Aug 23, 2011 7:43 am
Heater fan
Even if the heater fan isn't on?
Post Posted: Tue Aug 23, 2011 7:50 am
are you sure its not on :) if it does it again wind it up to full and back again
otherwise it might be stereo motorboating but it looks off and they dont really do that anymore
Post Posted: Tue Aug 23, 2011 7:54 am
wow that is a strange one!
Up under the dash on the passenger side is a modual about 4 inchs long and 3 inches wide. It has something to do with the engine polution control AFAIK. Perhaps it is that. Buggered if there is any wiring in the passenger foot well?
Is the handbrake switch earthing out? Its about the closest to the footwell.
255 characters
thats weird.. i have a kind of like that noise that comes and goes behind my dash.. but in a different spot... mine sounds like a relay clicking on and off rly fast.....
Post Posted: Tue Aug 23, 2011 7:56 am
sounds mightly like a relay to me too... where are your headlight realays
255 characters
Post Posted: Tue Aug 23, 2011 7:59 am
according to the vid at start you at the ON position not the ACC
255 characters
Post Posted: Tue Aug 23, 2011 8:08 am
Yeah, not the heater - it's definitely off. Headlight relay is under the bonnet. Sorry, by 'acc' I mean key is fully turned but not far enough to crank the starter.
I was thinking earlier - it's only happening on the coldest of mornings, maybe the LPG fuel line is half frozen, and this is the noise being made when pressure is trying to work through the line?
Definitely sounds louder inside though :?
Post Posted: Tue Aug 23, 2011 8:11 am
gas wont flow if the engine isnt running
Post Posted: Tue Aug 23, 2011 8:17 am
so is a resovior up near the engine? Or does it start on petrol then switch over?
255 characters
Post Posted: Tue Aug 23, 2011 8:26 am
100% LPG. No petrol at all.
There's a safety shut-off valve at the LPG tank, and there's a bigger shut off valve right before the regulator.
I think turning the ignition opens the LPG tank valve (you can hear this distinctive click when you turn the key) and builds the pressure to the valve at the regulator, and when you crank key to the starter position it opens the second valve so that the motor can be fed.
I think the line in between the valves could be freezing up with a fresh burst of pressure (+ cold morning), but I could be completely wrong. Might explain the extremely hard starting on cold mornings too.
Post Posted: Tue Aug 23, 2011 9:24 am
i would just pretend that there is no noise and if something stops working then you will
know what it is. if it never goes away and everything still works then ya didn't waste any time on something that doesn't matter.
Users browsing this forum: No registered users and 791 guests
