It is currently Thu Jul 30, 2026 12:06 am
Post new topic Reply to topic  [ 60 posts ]  Go to page 1, 2  Next
Post Posted: Thu Aug 25, 2011 11:42 pm
Hi
Currently i have a standard 1.3 in my sierra. As my project is only a trailer-ed crawler running 35's or 37's i am looking at power options if i need to. What would the best type of engine be for this project:
standard 1.3
injected 1.3
1.6
4AGE Bigport
Bigger diffs, auto trans, 6.5 gears
I would like some advise which way to go..
Thanks
Post Posted: Thu Aug 25, 2011 11:46 pm
Personally, if you can get enough gearing into it i dont think you need a huge amount of power.
some thing efi will be nice though
Post Posted: Fri Aug 26, 2011 12:06 am
i reckon a 1.6 EFI would suit this perfectly... you get more torque and power, but not enough to start breaking things, and it will work on crazy angles better than a carby setup.
Vehicle: WR250F/Jeep XJ
Post Posted: Fri Aug 26, 2011 12:09 am
yeah keep it light if you can...you would kick ass with something like a G13B DOHC GTI motor, into a 3spd vitara box with 5.12 diff gears and 6.5 tranny. Would have heaps of gearing probably too much but you would crawl anything.
(possible to use the BenT kit backwards to achieve this??)
Probably easier is a G16 vitara motor with 3 spd auto and 6.5s and 4.57s or 5.12s in the diffs. You're probably using hilux diffs or somethign so diff gearing is heaps of options there.
PS Gearbox choice is probably more important than engine choice. Go for an auto, crawling is just so much better.
Dan
LIKE US ON FACEBOOK - KPD4x4
Post Posted: Fri Aug 26, 2011 3:00 am
Dan
http://www.trailtough.com/index.php?pag ... &Itemid=53
Post Posted: Fri Aug 26, 2011 3:42 am
Post Posted: Fri Aug 26, 2011 4:10 am
jonno_racing wrote:
3.8
$3.8 is what your concession card saves you on your bus ticket?
come on dude, a little more info :P
Vehicle: Yamaha scooter, 50cc
Post Posted: Fri Aug 26, 2011 4:40 am
I'm guessing 3.8L v6 commonwhore motor
Post Posted: Fri Aug 26, 2011 5:54 am
Im guessing 3.8 diffs.. not quite the 3.9 but alittle higher than the 3.7's
:no:
Their only advantage is price.
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Fri Aug 26, 2011 5:59 am
BEST option
http://www.h1v8.com/page/page/1562068.htm
Or, a wacky idea
http://www.acpropulsion.com/products-drivesystem.html
Either way you wouldnt get change from $20k.
Post Posted: Fri Aug 26, 2011 6:27 am
sideways wrote:
:no:
is that why alot of the big boys run them
its a truggie where talking about not a road driven sierra
I'm busy,your ugly,have a nice day
Post Posted: Fri Aug 26, 2011 6:40 am
yeah 3.8 was a joke..
id look at something small/light and powerfull.
whats your budget?
4agze would be nice..
Post Posted: Fri Aug 26, 2011 6:44 am
whats your budget?
Budget would be around $2000 including auto... This is not a big dollar machine, just my capable toy...
Post Posted: Fri Aug 26, 2011 6:47 am
3.8,t700,lt230
Post Posted: Fri Aug 26, 2011 6:55 am
=wardy= wrote:
sideways wrote:
:no:
I assume so. It's a big, heavy lump that makes bugger all power for its size.
It's advantages are cheapness and parts availability. It's usually everything else that you look for when picking a competition motor.
The 3.8 might make sense in something a bit bigger(eg hilux), but not a zook.
Post Posted: Fri Aug 26, 2011 7:08 am
I know of 2 of australia's top suzuki going this way [matt white for 1]plus the snake buggie and I think 1 of pirates suzuki based buggies has this motor
I run a 1.6 efi ,3 speed auto ,hilux transfer but i am upgrading to 3.8,t700,lt230
Post Posted: Fri Aug 26, 2011 7:24 am
Different strokes for different folks mate.
I'd rather a lighter engine making the same power, even if it costs a bit more.
Obviously you'd rather the 3.8.
Post Posted: Fri Aug 26, 2011 7:37 am
After seeing the 3.8 in action in a hilux with the T700, I rate them as a wheeling motor. They are sooo cheap, parts are cheap, gearboxes are cheap...
I reckon it would make a good motor in a lwb zook if you could set the motor way back into the firewall area for weight distribution.
We always joke about a 302injected windsor and 2 speed power glide in zooks. would be mad :P
my 20v is awesome. with an auto is even more awesome. but it cost me about $4gs now to get it reliable with the auto strong enough to cope.
Post Posted: Fri Aug 26, 2011 7:40 am
when you upgrade I might be interested in buying your running gear...
It is a good debate and yes different options available.... I personally think I will go with a 1.6 EFI, auto...
Post Posted: Fri Aug 26, 2011 8:01 am
If your considering a big motor think hard about buying a complete rangie... cheap, lots of coil conversion bits. Good auto and transfer. Lots of pluses
Post Posted: Fri Aug 26, 2011 8:07 am
X2 ok power and fairly light
a commodore 3.8 would be ok if were alloy and weight less than half you zook
Post Posted: Fri Aug 26, 2011 8:50 am
evo or galant donk mated to scorpion rwd box
Post Posted: Fri Aug 26, 2011 9:18 am
or you could just leave the 1.3 in and gear it right :) the only problem i can see with the 1.3 is stalling because of angles with carby also think about auto boxs they make life easyer and are nicer on drive line
Post Posted: Fri Aug 26, 2011 9:23 am
The question was the best motor for a crawler.
I say an EFI 1.3/1.6. Beyond that, crawling is all about gears and an auto.
Greg's G13BB/Jimny auto is all that car has ever needed, running a 4:1 transfer and 5.12's.
However, lower traction surfaces and long hills, more wheelbase and better axle control, plus a more absorbent suspension means that sometimes there's no such thing as too much power.
That's not crawling though, and it's far from the forte of a sierra based car.
G16B
Post Posted: Fri Aug 26, 2011 9:36 am
yeah like I said 16b efi with an auto will be the way to go.. it is not a race car so low gearing and a good set up will be the way to go...
Post Posted: Sat Aug 27, 2011 10:05 am
if i were to build a crawler i would want it to be able to smoke 36"s on rock and a geared 1.3 (unless turbo and efi possibly) or 1.6 could not do.
Post Posted: Sat Aug 27, 2011 10:10 am
I can smoke 34's on rock with a 660 - 7500rpm 3rd low, dump the clutch.
I sometimes want more power than the 660 can deliver, but it's not for anything called crawling.
Vehicle: 4wd
Post Posted: Sat Aug 27, 2011 10:41 am
Depends on how you want to smoke. I can turn my 31's in 4th low in the shed on the brakes. They don't spin at a high speed, but the smoke.
The last thing I would want in a crawler would be to smoke exspensive tyres :)
Watch out or you'll get sued.
Users browsing this forum: No registered users and 622 guests
