[ 6 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
lump_a_charcoal
Joined: Wed Feb 28, 2007 10:30 pm Posts: 4454 Location: Botany, NSW
Vehicle: MY2019 Jimny
 Posted: Fri Nov 14, 2008 1:16 am |
G'day all
I am going to install some bumpstops, as my sierra has none.
It is SPOA with 31s, so how much should the bumpstops be extended?
Also, can someone post up pics of how to do it?
Will they need to be changed if I go RUF or move the diff forwards at all?
Thanks, Linc.
Dee
Joined: Tue Jul 10, 2007 11:30 pm Posts: 222 Location: Sunshine Coast
 Posted: Fri Nov 14, 2008 1:29 am |
are you getting any tyre rub at full flex?
Do your shocks have internal bumpstops?
If no to both of these, flex your car up to full stuff front and rear, measure distance from compressed side of diff (the one flexed into the guard) to the underside of your chassis rail directly above the diff.
Then fit bumpstops that are about 10 - 20mm bigger than this space.
Can be done a number of ways. (standard sierra bumpstops with spacers, aftermarket ones, one from a differernt make/model of car)...
_________________ Don't worry, It's only a suzi...
http://www.auszo
lump_a_charcoal
 Posted: Fri Nov 14, 2008 1:32 am |
I have rancho 9000 shocks, dunno if they have internal bumpstops...
I rub the footwell on flex, I'll do some measurements on the weekend.
Thanks.
Brett
Joined: Tue May 27, 2008 11:30 pm Posts: 1791 Location: Central coast NSW
 Posted: Fri Nov 14, 2008 1:50 am |
if its the std springs i'd move your diff forwad 22 mm. this helps heaps with scrubbing!
bump stops, look for some hilux bumpstops that you can bolt onto your ubolt plats and then use some thick waled rhs bolted to your std spots to space out the rest.
lump_a_charcoal
 Posted: Fri Nov 14, 2008 2:17 am |
I have 2 inch springs too...
On a side note, if I redrill the rear spring hanger, and redrill the spring perch, how much forward movement could I achieve?
BlueSuzy
 Posted: Fri Nov 14, 2008 4:35 am |
As much as you want, but too far and you will want to fit a spacer..mine is 25/30mm forward. Half ruf, redrilled perch etc
Mine WAS just 25mm forward redrilled perch and ubolt plate. Not hanger.
[ 6 posts ] |
Users browsing this forum: Google [Bot] and 193 guests
