It is currently Sat Nov 14, 2026 2:49 pm
Post Posted: Sat Aug 27, 2011 7:29 am
I am after an auto gear box... anyone have one that will bolt up to my 1.3
Vehicle: 79 Lj80 stockman 94 swb Sierra
Post Posted: Sat Aug 27, 2011 7:40 am
no dice.... australian sierras never came with an auto box.
Altho i have heard that u can buy an adaptor kit to run a vit 3 or 4 speed auto off a G13
We are amphibious
Post Posted: Sat Aug 27, 2011 7:43 am
Sounds like the perfect excuse for a 1.6 upgrade 8)
Post Posted: Sat Aug 27, 2011 7:49 am
The only auto will bolt to a sierra 1.3 is a Jimny auto. These are A) Rare B) Expensive C) need a big cooler and correct gearing and D) are electronically shifted so need a TCC interfacing to an ECM to shift them.
It's not feasible to bolt one to a carby 1.3.
IMHO unless you have an EFI 1.3 or 1.6 (carby or EFI) you don't want an auto. It's not going to drive very well.
Time to swap in a carby 1.6/trimatic, EFI 1.6/trimatic, or a vitara EFI 1.6 and AW-4 (but be prepared for quite a lot of work for the AW-4 - they are long and huge.)
also be aware that tyre size and gearing becomes quite tricky with a trimatic in a sierra. They like tall diff gears and big tyres.
Post Posted: Sat Aug 27, 2011 7:58 am
Again looking on the net at a few trucks and a few of them run EFI 1.3 and an auto...
So do I go with a trimactic and and either a EFI 1.3 or 1.6... Just after some info...
Post Posted: Sat Aug 27, 2011 8:03 am
So do I go with a trimactic and either a EFI 1.3 or 1.6... Just after some info...
everyone has tried and test alot of stuff so I would like to get the Sierra done without wasting more money.. Already got ripped off from the F*&Ktard who sold me the car...
Post Posted: Sat Aug 27, 2011 8:38 am
You have a thread here with a link to some of what you need to fit an auto to the 1.3
If you keep the carb motor it will be gutless.
There is a few threads about on auto's if you have some time to read. ;)
Post Posted: Sat Aug 27, 2011 8:45 am
Yes I shall do a search and read what has been written....I will not be keeping the carb motor. As i said the reason I am asking alot of questions is to get the set up right cause as it stands I lost a lot of money (now I see) on the purchase of the current ride. What I though was a good deal ended up being a complete rip off.. So that is why I ask.... try $6000 for my junk, rust hidden, lift kit that was shit and body damage.. So hence the questions...If someone was to tell me a good set up that works I will get it done.. There a thousand and one ways to set it up but only a few work...
Post Posted: Sat Aug 27, 2011 9:42 am
Shanej wrote:
There a thousand and one ways to set it up but only a few work for what I want to do...
I'll use an example- The trolley tug runs a Baleno G16B with a trimatic, 6.5:1 transfer gears, 3.9:1 diffs and Q78 tyres. (35.5")
It pulls 4000rpm @ 100km/h, pulls a treat, and has sweet gearing on road and off, but on 31's it would be rubbish.
Greg's car runs a G13BB, Jimny auto, 4:1 transfer, and 5.12 diffs with 35's.
Both cars are very hard to split off road. On road, the G16 car has more punch than the G13 car, and it was a cheaper engine gearbox combo.
Greg could run smaller tyres, Michael can't.
Sorry for the tech in the wanted section, but you have to know what you want.
Post Posted: Sat Aug 27, 2011 9:55 am
I know what I want and that is why i am asking for the combos:
I want something that will crawl and will run fine using 35 to 37" tyres.
This combo below is more like what I will need.
I am after a combo that works and i will find the parts I need and get someone to build it...
