It is currently Tue Oct 20, 2026 4:34 am
Post Posted: Sun Aug 28, 2011 12:20 pm
hey guys went for a trip out to glasshouse today and my mate started going up a hill in two wheel drive then stopped on the hill to change to 4 low and it ended up just getting stuck in neutral and suggestions on what to check. It's a WT sierra.
Post Posted: Sun Aug 28, 2011 12:38 pm
You need a new shifter bush.
Post Posted: Sun Aug 28, 2011 12:41 pm
okay so were would be the best place to get one from
Vehicle: 4wd
Post Posted: Sun Aug 28, 2011 12:44 pm
Bruce
Suzuki
Suzistore
maybe repco
ebay
Watch out or you'll get sued.
Post Posted: Sun Aug 28, 2011 12:45 pm
yea i was thinking Bruce might sell them i will send him a pm thanks for the help hopefully that fixes it.
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Mon Aug 29, 2011 1:07 am
In the mean time if you cant get a gear take the shifter out and put in in 2wd with a screw driver.
Just move both pins up to the top dent I think it is.
Vehicle: 91 sierra
Post Posted: Wed Aug 31, 2011 11:02 am
mine got stuck, just used a big screw driver and jamed the case into 4wd hi, once i got it to move into 4wd high it worked fine again
K.I.T
Knight rider
d(^_^)b
Post Posted: Wed Aug 31, 2011 11:15 am
X2 Mine was the same, got stuck in neutral in my driveway luckily, pulled the shift lever out and was easily able to shift it with a big screw driver, i stuck mine 2 High, then reassembled the lever n cup etc, works fine.
I would be putting a new bush in anyway, its pretty common for them to flog out.
when you do this but make sure you stick the lever back in the same position so it fits up in the hole in the tunnel.
89 Zook Sierra with 6 inches and 31's
Users browsing this forum: No registered users and 432 guests
