It is currently Wed Oct 14, 2026 5:20 am
Post Posted: Mon Aug 29, 2011 9:38 am
hey guys :) im in the process of swapp;ing my allow front diff to a steel one(vitara) and when i noticed my new steel diff (i bought a complete diff assembly from a wreckers) had a nipple on the housing that looked like a air hose one. sure enough i pulled it apart and it indeed seems to be an airlocker. booyahhhhhh!!!! the strange thing is though that where the nipple emerges from the housing, the housing has a lump there as if it had the nipple 9or something) there from factory, whats the go with this?
so im pretty excited to get a locker as a bonus with the diff. What else do i need to actually get it to work? a compressor i realise but im not sure how the rest of the system works. i dont want to get arb shyze if i dont have to just coz its too dear, i was thinking of getting a compressor and the gear and a rear locker from chinasoong, but im not quite sure yet.
cooinceidentally i just bought a little compressor off ebay for like 100 bucks that i was just gonna use for pumping up tyres, can i just use this for the system? or is it totally inappropriate? i dont really know much about air lockers, so any thoughts and advice are welcome
thanks guys :)
Post Posted: Mon Aug 29, 2011 9:43 am
throw up a pic mate.. might help with identification of the part you are talking about
and if it truly is an air locker.. what a buy.
you could use that compressor but you would have to set it up with a pressure switch and a tank to hol the air at presure.
would be alot easier to just purchase the proper compressor
Post Posted: Mon Aug 29, 2011 9:47 am
it's no airlocker... it's the air operated diff centre that the GV's use as they don't have any type of free wheeling hub.
Post Posted: Mon Aug 29, 2011 9:54 am
oh dang now i feel like a loser haha, got excited for nothing. so what do i need to do with it? nothing? should i take it out or what?
i wasnt convinced at the start but with no pressure in it i could move bothj sides of the diff freely from eachother then we put a compressor on it and the appeared to me to be locked together, oh well.
also in a slightly not realted note, im putting manual locking hubs in too what do i do with the old air actuator lines? nothing? or do i need to block them off?
thanks
Post Posted: Mon Aug 29, 2011 10:08 am
is the air line hole at the bottom of diff centre?
Post Posted: Mon Aug 29, 2011 10:26 am
yeh there is, should i just weld it up?
Post Posted: Mon Aug 29, 2011 10:31 am
no, what is it going into?
if it's a Vitara you need to swap the diff gears over into the GV steel diff.
Post Posted: Mon Aug 29, 2011 10:32 am
The hose fitting screws in from inside.
I removed it, and screwed a bolt in, with lock tite.
For some time, I justed put a short hose on it,
and plugged the end.
You do need to block it, or crud could get in.
Post Posted: Mon Aug 29, 2011 10:36 am
I think one or both of us has misunderstood question.
I thinked??
Post Posted: Mon Aug 29, 2011 10:55 am
yeh its going into a vitara, thanks yeh im aware i gotta swap all the gears over ive got them both open im doing it tomorrow. so i'll plug up the air hole, bolt is a good idea.
Users browsing this forum: Google [Bot] and 307 guests
