[ 7 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
strutts
Joined: Sat Jan 22, 2011 2:05 am Posts: 57 Location: Melbourne
 Posted: Mon Aug 29, 2011 11:29 am |
hey guy,
Got a really bad shake in my 85 drover.. i had a snapped transfer mount, fixed that and now I got a fkn terrible rattle/vibration... I was wondering if maybe because my transfer mount was snapped it could have bent my tail shaft or something? I have no idea. my drovers a 1.6 turbo. Could it maybe be a wheel bearing or something? or my gear box.. it only happens when I accelorate but when they car is in neutral it doesnt vibrate.. so its either the gear box or back..
I'm lost..
ajsr
Joined: Sun Dec 28, 2008 10:30 pm Posts: 3712 Location: melb
 Posted: Mon Aug 29, 2011 11:31 am |
has it done a uni in the tailshaft??
christover1
 Posted: Mon Aug 29, 2011 11:32 am |
If You assembled Tail shaft wrong, it could do that.
Uni joints need to be "in phase."
That is be straight with each other.
christover1
 Posted: Mon Aug 29, 2011 11:34 am |
And Transfer case could be moved out of place slightly,
and be touching body, chassis etc, or stick hitting the body
christover1
 Posted: Mon Aug 29, 2011 11:35 am |
Could be the passenger side engine mount, too.
They can look ok from outside.
FullyZooked
Joined: Mon Oct 25, 2010 9:01 am Posts: 1009 Location: Bendigo
 Posted: Mon Aug 29, 2011 11:55 am |
I would start with driveshaft and unis.
Make sure both uni's are in phase with a angle tool. Both Unis must be within 6 degrees of each other or you will have vibes.
Given that you have broken a transfer case mount i'm thinking you killed a uni or the drive shaft is slightly out.
When replacing the mount did you make sure to put the rubber mount the right way round, same position it was before? This can change uni angle also.
_________________ Built Suzuki's shall reign Victorious.
strutts
 Posted: Tue Aug 30, 2011 7:43 am |
Hey guys turns out it was the uni and the tail shaft always a good thing... Thanks guys!
[ 7 posts ] |
Users browsing this forum: Google [Bot] and 282 guests
