It is currently Mon Oct 26, 2026 6:51 am
Post Posted: Wed Aug 31, 2011 3:36 am
ok i am thinking about putting a vit tank in the zook, they are bigger and my sj80... well its fucked...
questions tho...
do all the swb vit tanks take the in tank efi pump? and does any one have a pic of how they have done there mounts etc??
Post Posted: Wed Aug 31, 2011 3:39 am
No. They aren't bigger.
SWB carby = 42L
SWB EFI = 42L
LWB EFI = 55L
Both carby and efi SWB tnks are dimensionally the same.
Post Posted: Wed Aug 31, 2011 3:41 am
the carby ones dont have the swimmer pump.
they arent worth the work, I had one in my sierra.
a SV model one maybe worth it though if you can get it to fit
Post Posted: Wed Aug 31, 2011 3:47 am
are they the same as a sj80 tank to tanshi? as in can unbolt the pick up and bolt the efi one in??
atm my tank holds around 27ltrs... so that's a massive improvement. id like a sj80 tank but cant find one under $300!! and i am more likely to find a swb vit tank in good nick.
Post Posted: Wed Aug 31, 2011 3:49 am
The swimmer pump from any 1.6 vit will fit into a coly tank with a few small mods.
FYI SWB EFI tanks are as hard to fnd as coily tanks.
Post Posted: Wed Aug 31, 2011 3:51 am
not sure if they will take the pump, i would guess they might.
as far as mounts go, i shortened the rear drivers side one to make it level with the passenger side rear. then did the same to the drivers side front mount. drilled 4 new holes in the tank flange and bolted it up
Post Posted: Wed Aug 31, 2011 3:52 am
that was my question will a efi swimmer pump fit in to a vit carbi tank.
Post Posted: Wed Aug 31, 2011 3:54 am
ok so not 2 much work then! great!
Post Posted: Wed Aug 31, 2011 3:55 am
Oh, sorry. I mis-read. Not sure on that one. The carby tank probably won'y have a swirl pot though.
Vehicle: 4wd
Post Posted: Wed Aug 31, 2011 3:58 am
They fit without any mods.
Watch out or you'll get sued.
Post Posted: Wed Aug 31, 2011 4:00 am
I found that the pump cage is a little short. If you extend the pickup hose and the cage by 30mm you can grab every last litre from the tank.
Vehicle: 4wd
Post Posted: Wed Aug 31, 2011 4:02 am
Ah ok. I thought by fitment you meant how they bolt up. I guess it's not a bad thing sucking up all the rubbish tho.
Post Posted: Wed Aug 31, 2011 4:06 am
Thanks guys... stock man your avatar just flipped me out! lol
isnt a sj80 tank only 35ltrs to start with???
thanks pete i will exend him down a bit.. not a big job!
Post Posted: Wed Aug 31, 2011 4:07 am
should be same as normal sierra, 40L
Post Posted: Wed Aug 31, 2011 4:08 am
42L for all sierra tanks. Although I think the 1L ute tanks were 40L?
Just make sure your pickup clears the bottom of the tank.
Post Posted: Wed Aug 31, 2011 4:20 am
JUst remembering.
you wont fit a vit tank very easily without a body lift as the filler pipe wants to run through where the chassis rail is
Post Posted: Wed Aug 31, 2011 6:09 am
yeah no issues tanshi i have a bl in the coiler of death.
Post Posted: Wed Aug 31, 2011 8:19 am
Jonno - pump the dents out of your existing tank and drop a Vitara pump in it. Fitting a vitara tank is a heap of fabrication work ( It probably won't even clear your exhaust) and it's not required for your application - you already have a tank designed to take an EFI pump.
Post Posted: Wed Aug 31, 2011 8:25 am
His tank may aswell be a sprinkler. Its fooked.
Post Posted: Wed Aug 31, 2011 8:28 am
Hmm. Fair enough. I think either way it's a hassle then.
Maybe modding a leaf tank to take a vit swimmer pump?
Post Posted: Wed Aug 31, 2011 9:00 am
this is my tank Steve... i have bronzed up that crack... however it just keeps leaking from prev damage, every 6 months or so.. over it... and it holds sfa fuel! it has the swimmer pump in it..
(it is pressurized in pic with hose btw)
looks like i just found a swb vit tank in perfect cond for $20.. does any one have any pics of how they have done there filler with the vit tank?
Post Posted: Fri Sep 02, 2011 3:56 am
went to go pick up the swb tank today, and it does not have the opening to put the swimmer pump in!!! :( looks like my old one will be going back in till i find a better one.
Post Posted: Fri Sep 02, 2011 5:24 am
Thats cos its a carby tank. You need an EFI SWB vit tank, or a coily tank.
Post Posted: Fri Sep 02, 2011 5:49 am
Yo, jonno, look in my build I moved my filler onto ontop of my tank so It comes though the floor. If you have a 50mm body lift you can run the filler through in between the body and chassis. I just pulled out my shock cross member and remade it to suit the vits tank. I'm going to remount it a fair bit higher next time.....
Post Posted: Fri Sep 02, 2011 7:14 am
i was just cleaing it up as tanshi said you could!
i will have a look thanks mate.
Users browsing this forum: Google [Bot] and 242 guests
