Joined: Wed Jun 15, 2011 2:25 am Posts: 151 Location: australia port augus
Posted: Thu Sep 01, 2011 12:46 pm
hi guys got a 1.6 efi vitara motor in my sierra and got a small problem. when i drive the car normally it drives fine but soon as i put my foot flat it kinda bogs down with a weird "deep missing" noise? i disconnected the afm wile the engine was running and the revs jumped up so im guessing thats still fine. but i think it might be the o2 sensor because its wired to the ecu with just normal wire like what comes out of the ecu. is the 02 sensor supposto be wired a certain way?
it will be anything but your 02 sensor. with your foot flat the ecu won't be taking any notice of the 02. check your ignition system starting with those bakerlite spark plug lead tubes. look for white spots were the spark has been jumping through the side of the tube to the head.
Users browsing this forum: Google [Bot] and 280 guests
